Go to Post of course, like anything, there is big difference between "can" and "should" - ratdude747 [more]
Unread 08-06-2010, 22:31
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: What Makes A Good Leader?
Ok Zach, thank you for your wonderful post, but I do not want to quote it for the sake of the readers. I will say this, I love programming, no question about it, joined robotics for the sake of programming. Now here is where the problem starts, I am terrible at teaching. If you program, it is more about how you think, not the syntax. I code in C++ and Java, we used Java this year, which I personally do not like. Also I told my mentors straight up, I will use C++ next year. Now that I think about it, if I want to be a leader, I probably have to make sacrifices myself, Java is easier to learn than C++. I have 2 more years for robotics, which is not a lot, that means someone else has to step up after me. I think it is better in the long run to have the programmers suffer a little bit learning C++. I am already putting in the extra mile with my mentors, you know about my little autonomous robot project (check my sig). I think the major thing I lack is the ability to teach and patience. I sometimes even freak out (not literally) just a major facepalm moment when guys use too many if statements to do something. Yes, I need to mature on that part if I want to be a leader
edit: Would you find it rude if a Junior ran against you for a leadership position if you were a Senior? I am not sure if this guy is going to run again, but he was the programming leader this year, but I pretty ended up being "the" programmer...
What makes for a good and spectator-friendly game? Chris Hibner General Forum 12 22-04-2009 13:33
What makes a good teaser photo? Tom Bottiglieri General Forum 8 27-01-2005 06:03
what makes a good robot Michael Leicht General Forum 19 20-04-2003 01:09
What makes you such a good scouter Raul@13 Scouting 6 04-03-2003 21:22
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
