Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 18-02-2010, 18:16
nikRbokRz nikRbokRz is offline
FRC #1683
nikRbokRz is an unknown quantity at this point
Exclamation Waiting for cRIO to reboot
Hi,
I've gone through the recent required updates for the FRC Squawk.
However, I now have an unusual problem. When I upload code, the message "Waiting for cRIO to reboot (XXXs)" appears. It never goes away (and the time keeps increasing). As a result, I can no longer view any System.out.println()'s.
It's interesting, because another programming team member has also updated the FRC Squawk stuff, but he is only getting to "Waiting for cRIO to reboot (10s)" - which is what I used get - and then is able to view the print statements.
Any ideas on why this is happening, and how I could fix this?
Unread 18-02-2010, 18:19
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Waiting for cRIO to reboot
Does restarting the Driver Station/Dashboard when it's waiting help?
Unread 18-02-2010, 18:29
FRC #1683
How exactly would I restart my Dashboard/DS? I have my ClassmatePC on at all times.
Unread 18-02-2010, 18:39
Programming
What's your driver station / developing setup? Are you uploading code from another computer?
Unread 18-02-2010, 18:56
FRC #1683
Yeah, we're all programming from our own laptops, and then uploading code wirelessly, using the bridge.
It used to work before the update, but since then it's not working (and only for me, it works fine for my teammate).
Unread 18-02-2010, 19:49
Programming
Try running the driver station and dashboard on your laptops. We used to have a problem where we got a similar problem. We fixed it by closing the dashboard and opening it while the code deploys.
Unread 19-02-2010, 16:26
FRC #1683
But it's not really "laptops". It's just my laptop that doesn't work correctly. It deploys code, it's just that I can't get print statements.
Unread 20-02-2010, 17:17
ygd ygd is offline
FRC #3341 (Manhattan Project)
ygd is an unknown quantity at this point
Make sure the subnet/netmask is set to 255.0.0.0. We had this problem too until we changed it.
Unread 22-02-2010, 17:07
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
One test that you should try is to run the "echo" target on the build.xml of your project in NetBeans. Then reboot the cRIO. If you get output after a while that is the console out of the cRIO then you know you are getting good communication from the cRIO. If not, then you may have the mask issue pointed out.
Unread 25-02-2010, 15:28
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
I've got one for you. The other day, after installing every imaginable update, we were getting "Waiting for cRio to reboot" scrolling indefinitely on the console. After some experimentation, I realized that code was loading on the robot and the reboot was occurring, but we just weren't getting the appropriate console output. So, I checked the IP settings for the network card on my PC and discovered that we were using DHCP. So, I changed it by manually setting the IP to 10.22.72.6 (team 2272) and the console update correctly and I no longer received indefinite waiting to reboot. FYI.
Unread 09-06-2010, 15:11
Phoenix.14's Avatar
Phoenix.14 Phoenix.14 is offline
AKA: Thomas
FRC #1757 (The Wolverines)
Phoenix.14 is an unknown quantity at this point
We're having this same problem when we try to load code onto our cRIO. We have the laptop hooked into the wireless bridge, although we've also tried a direct cable into the cRIO. We use java with netbeans, and we're trying to load a new project onto the cRIO; unfortunately, whenever we select Run Main Project, the output scrolls indefinitely on "Waiting for cRIO to reboot (<x> s)". After 15 or 16 seconds, the Classmate driver's station regains comms with the robot, but continues to read "No Robot Code". When we reset the robot, it still has no code. Does anybody have any other tips on how to solve this problem?
Unread 10-06-2010, 08:47
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
It sounds like you have a laptop and a classmate. The classmate seems to be running correctly (at least the driver station is getting some comms from the robot), but the laptop is only getting part of the job done.
If you got to "Waiting for cRIO to reboot", then the ftp phase should have completed, so the laptop also has some communication to the cRIO.
The most likely issue is that the netmask of the laptop is not set to 255.0.0.0. The DHCP on the wireless router really wants to change you netmask to 255.255.255.0, but don't let it!
Another thing to try, as Eric pointed out, is to watch the cRIO output from the command line. So on your laptop, open up a command/terminal window. Do a "cd" to your project's directory, and type "ant echo". Then manually reboot the cRIO. You should now start seeing the cRIO's boot messages etc.
If none of this works, please post the output of your "Run Project" command.
Unread 14-06-2010, 10:01
Phoenix.14's Avatar
AKA: Thomas
The subnet mask was already set to 255.0.0.0, and for some reason I couldn't get the 'ant echo' command to work.
However, I tried making a new robot project and copy-pasting everything into the new project, and for some reason it works now.
Unread 15-12-2010, 21:22
ksanger's Avatar
ksanger ksanger is offline
FRC #0211 (MaK)
ksanger is on a distinguished road
We have Java running on two computers. One with Win7 sees the cRIO boot. The other running WinXP waits forever. Subnet mask is set to 255.0.0.0. We have tried with the Classmate turned off, with the Classmate on and logged off, and with the Classmate on with driver station running.
On the XP laptop we have turned firewalls off. IP is set to 10.2.11.6. Also tried 10.2.11.11. We use a Linksys router between the classmate, laptops, and the robot. The XP laptop may ping the router and the cRIO, however it fails to ping the Classmate. I don't have the Netbeans and Java versions handy. We loaded from the web, then added the pluggins from the update site.
I'ld really like to get the XP Laptop running as that is the laptop that belongs to the team. Any other ideas to try? Note the XP Laptop is a school laptop so the account type may be an issue? Plus permissions are set by the school district?
Unread 27-01-2011, 18:15
gordo161101 gordo161101 is offline
AKA: G. Lange
FRC #2439 (BHS Robotics)
gordo161101 is an unknown quantity at this point
We have a similar problem, two laptops with Java installed, one Windows 7, the other Windows XP. Code uploading from XP hangs with message "Waiting for cRIO to reboot". Run the same code on Windows 7 with expected result.
Is there a problem with Windows XP? Is there a work around? Thanks.
"Waiting for Prompt" in Netbeans from cRIO joshholat Control System 6 26-01-2010 10:33
Need to manually reboot cRIO to download code FRC4ME Java 6 24-01-2010 15:59
cRIO loses code on reboot? boris FRC Control System 1 30-01-2009 10:42
Waiting lists for FLL teams Woe Lego Mindstorm Discussion 5 21-08-2005 00:58
Waiting for Kick Off archiver 2000 4 23-06-2002 22:03
