Go to Post don't be grumpy. No one is allowed to be grumpy during build. - JaneYoung [more]
Unread 09-06-2010, 21:31
Wildcat's Avatar
Wildcat Wildcat is offline
AKA: Jeff
Team Role: Scout
Wildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the rough
Re: It's NOT a watch...
Originally Posted by Andrew Schreiber View Post
The real question, can we make it play Doom?
in theory it should. if it has usb interface for a pc, then therefore that would make it an interface device of said pc. Now if an xbox 360 controller is also a usb interface which would mean it could be used to control something like doom assuming doom is compatible with it. now if the same logic can be applied to the watch and doom is compatible with it, in theory it would work, but then again a lot of things work in theory but not actuality.
Now what would really be cool is if my same logic from above could be applied to the classmate and an FRC robot. if you could get 2 watches, one for each arm, you could control your robot through motion such as dance. EX: the better you dance the better your robot would preform
Network switch: $25
Gas, drinks, and pizza for a road trip to Troy:$50
Mountain Dew, Nachos, and Pizza at States:$200
Being a member of the Scouting Team: Priceless
2010 & 2011 Scouting Coordinator
2010 Back-up Driver (2-5)
It's Championship, Not Nationals Joe Matt Championship Event 150 09-04-2010 14:54
Watch Dog not fed? Dawl Programming 6 13-02-2010 13:12
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
pic: It's not a Flute... Sachiel7 Extra Discussion 1 29-01-2005 07:50
It's Not Fair??? archiver 2001 2 24-06-2002 00:28
