Go to Post Who cares about the score? The score is just numbers on a board, the exciting part is watching the robots interact and seeing robots( and more importantly, people) do the impossible. - Herodotus [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 10-06-2010, 00:09
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Do black jaguars come with functional CAN firmware?
Are the black jaguars addressable via CAN out-of-the-box?
I understand there is a firmware update that's supposed to happen for FRC use, but that must be done with either CAN or jtag.
Is there some way to update firmware over serial that doesn't use the CAN bus?
-- Marshal Horn
Unread 10-06-2010, 01:35
Re: Do black jaguars come with functional CAN firmware?
Marshall -
There is a good chance I'm about to answer the wrong question. Please don't hesitate to correct me.
The black jaguars can be updated over serial without any CAN bus connections. Simply plug the serial adaptor (the 6 conductor blackwire) in to your laptop and load new firmware.
Unread 10-06-2010, 11:09
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Originally Posted by EricVanWyk View Post
Marshal -
You mean with the BDC-COMM? I'm pretty sure that goes through CAN. (That is, the data goes from the serial line in to the processor, out the master CAN controller, and into the slave CAN controller, and then into the processor. When nothing is hooked up to the serial port, only the slave CAN controller is used.)
Is there another utility you're referring to?
(You are correct, this is my secondary question if the answer to the first question is "no").
-- Marshal Horn
Unread 10-06-2010, 12:06
BDC-COMM goes through Serial to a Black Jaguar, which translates to CAN. If you are talking to a single Black Jaguar, it just uses serial.
Unread 10-06-2010, 18:39
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Okay, I see what you're saying. There's only one CAN transceiver.
Let me see if I can update the firmware without having to address a device number.
-- Marshal Horn
Unread 10-06-2010, 19:03
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Okay, I got "Unable to contact the bootloader!". (I have BDC-COMM version 89)
I'm going to wait until my first question is answered before I try much harder to fix what might not be the problem. My Jaguars appear to be fully functional in every way except CAN or (perhaps) Serial communication.
Is it normal for Black Jaguars to echo back every serial message they get?
-- Marshal Horn
Unread 10-06-2010, 19:26
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Is this still the same adapter that you were using earlier?
It sounds like you don't have any communications to the Jaguar, and as such, the "Failed to contact the bootloader" error makes sense.
Have you tried other adapters?
And you are sure that the pinout is correct on your adapter?
Do you have more then one black jaguar? if so, try communicating with that one.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 10-06-2010, 19:41
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Yes to all.
I'll make it clear when this topic is open-ended.
I have two questions currently:
Do the Black Jaguars work with CAN out-of-the-box?
Is it normal for them to echo back serial data that is sent to them?
Another way of phrasing this is:
What is the functionality of the firmware on the Black Jaguars when they are shipped?
EDIT:
Upon re-looking at the getting started guide, it appears that the only difference between the default firmware and the FIRST firmware is the "untrusted mode".
I mis-spoke earlier in this post. I haven't tried a different adapters, but I have confirmed (with an oscilloscope) that my adapter is sending and receiving data.
-- Marshal Horn
Unread 11-06-2010, 20:56
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Well, I found the problem was with my adapter; the pin-out was backwards.
However, it's a commercial female RJ-12. It was manufactured with the colors backwards.
-- Marshal Horn
Unread 12-06-2010, 01:36
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Umm, no actually, CAN is backwards. This was my #1 complaint about CAN. You cannot buy off the self cables. You have to make them. This is very error prone. We spent several weeks debugging CAN because we kept getting something wrong in the cabling. Once the cables were right it seemed to work fine.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
CAN with more than 2 Jaguars KillerGardevoir CAN 9 03-04-2010 01:20
New Black Jaguars? NyCityKId Electrical 27 02-04-2010 10:38
Bricked black Jaguar after bad firmware update FRC4ME CAN 13 19-02-2010 16:52
CAN Bus Control via Black Jaguars -- SOLVED!! taichichuan C/C++ 6 15-02-2010 15:11
Serial to CAN Gateway in new Black Jaguars? dmcguire3006 Electrical 54 26-01-2010 07:32
