Go to Post All hail the amazing duct tape and the mighty zip-tie!!! :] - Gabe [more]
  #31   Spotlight this post!
Unread 10-06-2010, 20:00
Chris is me's Avatar
AKA: Pinecone
Re: Crazy Drive Train Ideas
Originally Posted by CENTURION View Post
For now my favorite solution is off-road swerve/crab drive, using two wheels on each pod (ok, I'll admit, the two-wheels part is mostly to make it look cooler, but it would have it's benefits: traction, weight distribution on soft material, etc)
Each pod would be individually rotated via an FP or Window motor, and would raise and lower via a pneumatic piston and some guide bars. (the pistons could be pressurized somewhat to create a passive suspension system).
You may be interested in this whitepaper. 1114 made a swerve drive somewhat similar to this in 2004.
  #32   Spotlight this post!
Unread 10-06-2010, 22:12
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by 548swimmer View Post
That is actually infuriating that is exactly how I wanted to go about it, minus the webcam although it is a nice addition.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
  #33   Spotlight this post!
Unread 10-06-2010, 22:26
NickE's Avatar
NickE NickE is offline
_
Originally Posted by Hawiian Cadder View Post
i just came up with another one, make a robot that is entirely encased in a hollow sphere with omni wheels on every corner facing outward, to drive the main part of the robot drives the inside of the sphere, if we ever get a water competition this would be highly helpful i think.
Have fun putting bumpers on that robot.
  #34   Spotlight this post!
Unread 11-06-2010, 02:16
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
First let me say that I dearly love XKCD and Randal Munroe. But he got it wrong. Just take a good look at those "omni wheels". They're mecanum...
I've been looking into making a drive train I recently read about in Servo magazine: Melty Brain. Basically, it's an effectively holonomic robot (overall it is, but instantaneous moments it isn't) that can be driven with only one wheel and one motor, but you can technically use as many wheels and motors as you want if you've got a fast enough processor. This site has a good explanation:
http://www.spambutcher.com/meltyb.html
I want to preface this description with the note that this drive train is absolutely terrifying, but if it's crowds you want, then crowds you'll have. The robot spins up really fast in a circle (no gear reduction on the wheels, in fact depending on wheel diameter, the CIM's might be a little slow) using the motor[s], and very precise timing allows you to vary the motor speed at specific points in the circle to effect a net vector that allows the robot to move around. If you think of it in terms of a polar graph, to go forward, you'e have a base speed, at 0, the motor would be going faster than that base speed, at PI/2 and 3PI/2, the motor would be spinning at the base speed, and at PI, the motor would be slower than base speed.
This is a fairly easy drive train to build (although it's harder with the size of robot you're building, you have to make sure the center of mass is relatively stable and all of your frame connections are very solid, otherwise the robot might try to rip itself apart). The hard part of this type of drive train is the code. You have to have either one accelerometer and know its radius away from the center of mass (the axis of rotation), or two accelerometers inline and know the distance apart (I like that one because it means you can change batteries without necessarily recalibrating). You measure the centripetal acceleration with the accelerometers, and with the radius information, you can figure out angular velocity. You effectively integrate that (multiply the calculated angular velocity in one loop by the amount of time between loops, then do it again next time and keep a running sum), and you'll end up with your angle. The angle is used to calculate wheel speed. The motor control is very simple, and can in fact be done with a PWM-capable pin and a large Darlington transistor or power transistor and a gate driver (the Darlington transistor is usually used because you can pick one up at Fry's for under $5).
I'd suggest making a small one (at least at first, probably a good size to keep it though) out of a small piece of 1/4" Lexan or plywood and a Fisher-Price motor and a Lite-Flite or equivalent high-traction wheel, and seeing how it goes before you think about moving up to anything bigger and more dangerous. It's been done before, but all for antweight (and one beetleweight) combat robots, so it would be cool to see what you guys come up with to do with it. An idea I had was to use a line of LED's and write messages in the air while it's spinning, but there are probably lots of other things you could do with it.
  #35   Spotlight this post!
Unread 11-06-2010, 07:32
AKA: Pinecone
Why is it infuriating?
Anyway, if you want a crazy drivetrain idea... Figure out a 4wd drivetrain that is not vulnerable to pushing that goes over the bumps that can turn. I wish I figured that one out...
  #36   Spotlight this post!
Unread 11-06-2010, 08:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
One that uses ackerman steering with zero mechanical trail
  #37   Spotlight this post!
Unread 11-06-2010, 08:54
AKA: Pinecone
It also has to zero point turn, sorry.
I saw one solution this year. Very forehead-slap moment for me. (Edit: I think with some adaptations, that same drivetrain could outperform a Nonadrive. Wait... I think I just inspired myself. CAD time!)
  #38   Spotlight this post!
Unread 11-06-2010, 08:58
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Pictures of the solution? Or Nonadrive for us un-initiated?
  #39   Spotlight this post!
Unread 11-06-2010, 09:18
AKA: Pinecone
*spoiler alert for teams that want to guess *
The pictures available don't show it, but 195 had a drivetrain with 4 high traction wheels. To turn, they had drop down omni wheels in line with the back wheel axles. It was an extremely clever solution that I feel stupid for not thinking of when I wanted a 4wd this year.
As for the adaptation, let me work on that one for a bit.
  #40   Spotlight this post!
Unread 11-06-2010, 09:38
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
I would like to make an adaptable drive train that is easily suited for most kinds of game play or game types
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
  #41   Spotlight this post!
Unread 11-06-2010, 11:00
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
What do you mean by "outperform" the nonadrive? Considering that the nonadrive effectively addresses a multitude of issues with both omni and 4wd while combining their strengths (and even manipulating a perceived weakness of 4wd), saying a drive train will outperform the nonadrive is a very broad, boastful statment...
Additionally, until you've driven a drive train with "modes" (linkage in 2008/09, nonadrive as implemented in '10), you really don't get a feel for the true power of a manipulatable center of rotation.
GitHub
  #42   Spotlight this post!
Unread 11-06-2010, 20:32
AKA: Pinecone
The random idea I thought of when I made the post had the capability of doing particular features better than a Nonadrive base. It was rashly typed, yes, but also an example of the kind of thinking that could get you to think up your next "creative" drivetrain. Start looking at drives that arent 6-drop and what advantages they have, and how to work around their drawbacks. Evolution is innovation.
  #43   Spotlight this post!
Unread 14-06-2010, 00:17
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
ok, here's a few sketches if you care to take a look:
This is 8-wheel swerve drive, with modules that can be raised and lowered (you can ignore pretty much all of the math and notes on there, that was me doing figuring on amounts of material for the whole bot)
(I will hopefully have Sketchup models done soon)
http://s226.photobucket.com/albums/d...rent=001-3.jpg
This is a triangular(ish) robot, with a single swerve module in the middle, and basically a kiwi drive around it (three omni's, each powered by a FP/Window Motor). The only reason the omni's are powered is to keep the robot from spinning wildly when you try to rotate the swerve module.
http://s226.photobucket.com/albums/d...rent=002-1.jpg
  #44   Spotlight this post!
Unread 23-06-2010, 01:12
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
We used that method as well, and it made so much sense once someone said it that everyone else was amazed they didn't figure it out themselves. Though, if you want to be picky, it is technically a 6 wheel drivetrain.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
  #45   Spotlight this post!
Unread 23-06-2010, 14:24
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
So I have another drive train running through my head. I was wondering what gear ratio would be used to power an individual wheel using a ban bot moter and what it would be for a fisher price moter. Also I thought i remebered that we only get 2 bb and 2 fp moters, is that right?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
Drive Train archiver 2000 1 24-06-2002 00:37
