Go to Post My advice is anytime your intuition tells you something, double check it with physics. - tennispro9911 [more]
Unread 11-06-2010, 12:30
isaacdl isaacdl is offline
I have a white hat..it's just dirty
AKA: Isaac Dontje Lindell
FRC #3018 (Nordic Storm)
isaacdl is an unknown quantity at this point
no control of bot when kicker is operating
We are working on learning Java as a precursor to next years season by programming this years bot in Java. We have tank drive working just fine, and the pneumatic kicker works just fine. The one problem we have is that one kick (out and in) takes about a second to complete. (Half second delay each way is programmed in to provide time for the cylinder to fully extend and retract). During that second, the we have no control over the bot. If it was driving (ie the joystick was moved forward or backwards) when the kicker is activated, the bot will *continue* to move at that speed and direction until the kicker cycle is done, even if we release the stick or change directions. How should we solve that?
842 Kicker On Bot kE7JLM General Forum 36 29-01-2010 11:51
How & where do you build the bot when it snows and your robo-base (school) is closed? Elgin Clock General Forum 28 03-03-2008 00:12
paper: Control an FRC bot with a Wiimote Greg Marra Extra Discussion 8 21-01-2008 12:41
1189 - Human-Bot Arm Control jmcr8on Robot Showcase 50 13-10-2007 22:58
