Go to Post I survived the Great CD Spamming of 2006. - Michelle Celio [more]
Unread 11-06-2010, 13:01
isaacdl isaacdl is offline
I have a white hat..it's just dirty
AKA: Isaac Dontje Lindell
FRC #3018 (Nordic Storm)
isaacdl is an unknown quantity at this point
Re: no control of bot when kicker is operating
It sounds like your "driving" code has to wait for your "kicking" code to complete.
If this is the case, there are two (at least) different ways to solve this:
1) put your kicking code and driving code into separate tasks so that the OS can multitask them for you,
or
2) use a state machine for your kicker code, so that it doesn't bring everything to a halt while it's waiting for the delay
We're trying option one right now, but having never had to program multiple threads, could you explain how to do it? We're trying various things we're finding on the internet, but none of it is exactly what we need.
If it matters, we're using SimpleRobotTemplate (so like Independent from LabView ) as opposed to IterativeRobot.
Unread 11-06-2010, 13:19
I wish I could give you more specific help, but I am unfamiliar with Java. I'm sure there's a way to do it. There are lots of good Java programmers on CD. One fellow is even currently writing a Java programming manual for FIRST:
http://www.chiefdelphi.com/forums/sh...ad.php?t=85836
maybe you could ask him.
Unread 11-06-2010, 21:34
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Another option is to create a kickerLoops variable, and allow a certain loops to go by before operating your cylinders. We did this for our kicker and it worked great, but getting the initial setup/timing down might take a while.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 11-06-2010, 21:50
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Give me a few minutes, and I can pull up our code, which an on-hand programming helper at the regional assisted us with. We had that exact same issue.
Unread 11-06-2010, 22:03
synth3tk's Avatar
AKA: David Thomas
Notes:
This is setup so that a button on a USB gamepad triggers the kicker.
Replace the sFire/sLatch/etc parts with your actual kicking code.
Depending on how your kicker works, you may need more or less "sections".
kickTime.start in the first block is required, and kickTimer.stop(); and kickTimer.reset();.
        // Set kicking loop to start when button 7 on gamepad is pressed and not in loop already
        Watchdog.getInstance().feed();
        if(gamePad.getRawButton(7) == true && kickTimer.get() == 0.0)
            kickTimer.start();
            sFire.set(true);
            sLatch.set(false);
            sExt.set(true);
            sRet.set(false);
        if (kickTimer.get() > 0.75 && kickTimer.get() < 1.05)
            sFire.set(true);
            sLatch.set(false);
            sExt.set(false);
            sRet.set(true);
        if (kickTimer.get() > 1.05 && kickTimer.get() < 1.35)
            sFire.set(false);
            sLatch.set(true);
            sExt.set(false);
            sRet.set(true);
        if (kickTimer.get() > 1.35)
            sFire.set(false);
            sLatch.set(true);
            sExt.set(true);
            sRet.set(false);
            kickTimer.stop();
            kickTimer.reset();
Unread 11-06-2010, 22:59
What you've posted is essentially a state machine, where the state variable is the value of kickTimer.
A generic state machine might look like this:
switch(kickState) {
case 0: // kicking is not in progress
if(gamePad.getRawButton(7) == true) {
start_the_kick_sequence_and_initialize_variables_a s_necessary();
kickState = 1;
break;
case 1:
if case_1_timer_or_event_has occurred(){
perform_case_1_action();
initialize_variables_for_case_2_as_necessary();
kickState=2;
break;
case 2:
if case_2_timer_or_event_has occurred(){
perform_case_2_action();
initialize_variables_for_case_3_as_necessary();
kickState=3;
break;
case n:
if case_n_timer_or_event_has occurred(){
perform_casen2_action();
initialize_variables_for_case_0_as_necessary();
kickState=0;
break;
The above has the advantage that it's a little easier to see how to use events (like limit switches etc) to change states, instead of being strictly timer-based.
Unread 12-06-2010, 00:44
synth3tk's Avatar
AKA: David Thomas
Thanks for the suggestions. I should have also stated:
I'm a non-student member (I guess a mentor, in some ways), and our team is extremely small. I couldn't even coerce any students to learn programming, so I had to learn Java with some small help from the team mentor (who knew very little more about Java than I did) and the internet starting 2 days from Kick-Off.
We were just getting the bare minimum working. But I'll keep that in mind for the future, if/when we teach the new programmers.
Unread 12-06-2010, 16:16
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
One solution for solving this in Java is threads. Team 997’s kicker this year takes 4.5 seconds to reload. It was extremely important for us to make sure the driver maintained control during this time. I’ve copied in some of our code below and removed most of the extra stuff it for you to see how we did threading on our robot.
A couple things to keep in mind.
1. It is vital your each thread of execution have either a Thread.yield() and/or a Timer.delay(). These are required to ensure each thread gets time on the CPU. Otherwise one thread could starve (not get any time on the CPU).
2. Put things like kicking that take a long time in separate threads, but keep quick things in the main thread. I accidentally put our gear shift in the kicker thread and the driver couldn’t shift while the kicker was reloading. We fixed this after regionals.
Main thread that starts kicker thread:
public class RobotMain extends SimpleRobot {
    final int Preload = 1;
    final int Retract = 0;
    final int Latch = 1;
    final int Unlatch = 0;
    private Joystick leftStick = new Joystick(1);
    private Joystick rightStick = new Joystick(2);
    public RobotMain() {
    public void operatorControl() {
        getWatchdog().setEnabled(true);
        KickerThread kickerThread = new KickerThread(this);
        kickerThread.start();
        while (true && isOperatorControl() && isEnabled()) {
            drivetrain.tankDrive(leftStick, rightStick);
            getWatchdog().feed();
            // DO NOT remove this yield. Required for kicker thread to execute.
            Thread.yield();
        try {
            kickerThread.join();
        } catch (InterruptedException ex) {
            System.out.println(ex.getMessage());
     * Gets the right joystick
     * @return The right joystick
    public Joystick getRightStick() {
        return rightStick;
     * Gets the robot ready for the big kick.
    private void makeReadyForKick() {
        //Not latched and needs to be preloaded.
        if ((preloaded == false) && (latched == false)) {
            driveLatchSolenoid(Latch);
            Timer.delay(1);
            driveShooterSolenoid(Preload);
            Timer.delay(1);
        //Latched, but needs to preload.
        if ((preloaded == false) && (latched == true)) {
            Timer.delay(1);
        //Preloaded, but needs to latch.
        if ((preloaded == true) && (latched == false)) {
            driveShooterSolenoid(Retract);
            Timer.delay(2);
            Timer.delay(1);
            Timer.delay(1);
     * Peforms the kick routine.  First loads the kicker if needed.
     * After kicking it loads the kicker for the next big kick.
    public void performKick() {
        makeReadyForKick();
        //Kick!
        driveLatchSolenoid(Unlatch);
        Timer.delay(.5); // If this changed, change the delay in autoKick!!!
        //Reload for big kick.
        Timer.delay(2);
        Timer.delay(1);
        Timer.delay(1);
        System.out.println("Kick Performed");
Kicker Thread:
public class KickerThread extends Thread {
    private RobotMain mRobot997;
    private Joystick mRightStick;
    public KickerThread(RobotMain robot) {
        mRobot997 = robot;
        mRightStick = mRobot997.getRightStick();
    public void run() {
        while (mRobot997.isOperatorControl() && mRobot997.isEnabled()) {
            if (mRightStick.getTrigger()) {
                mRobot997.performKick();
            Thread.yield();
In order to allow us to drive to the next ball in autonomous while reloading, we also used threads. The main thread just set a flag on the autonomous kicker thread's class to let it know when to go ahead and perform the kick. Does require being sure to write thread safe code.
Unread 12-06-2010, 16:36
frasnow's Avatar
Software
One point of clarification, since multithreading can be a confusing topic for some. Event though the performKick() method is located in the RobotMain class, the call to performKick() located in the KickerThread class' run() method still executes on the second thread. Any methods called during the While loop in the operatorControl() method are executing on the main thread.
Unread 12-06-2010, 16:59
Hey, welcome aboard frasnow. Check your Private Message inbox, I had a question about your post. :-)
Unread 13-06-2010, 03:18
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I'm not sure if Java has the same thing, but in C++ another easy way to do something like this (without having to worry about yielding, since it does it for you automatically) in a different thread is via the Notifier class. It calls a function every N seconds (we specified 0.0025 seconds) on a different thread. Then you just have your state machine in a single function and have it do the right thing (ie, operate the right switches and such) every time the function gets called. And as the other poster said, you have a different function that gets called by the main thread that touches the state variables.
Of course, a key thing when dealing with multiple threads is to make sure you deal with potential synchronization problems, by using the appropriate locking mechanisms. In C++, you can use the Synchronized class to do that.
I've attached our Kicker code in C++. The full version of our 2010 code is at http://www.virtualroadside.com/FRC/
Unread 13-06-2010, 09:10
Some thoughts for discussion:
Threads in C++ can be preemptive, regardless of whether or not they are created by the Notifier class. In any case, using cooperative multitasking techniques like releasing the CPU to service other tasks while waiting for an event or timer (block waiting) is good programming practice. It makes your code more responsive and avoids wasting CPU resources.
If the kicker code is properly implemented as a state machine, you don't need concurrency, and you don't need to worry about synchronization.
842 Kicker On Bot kE7JLM General Forum 36 29-01-2010 11:51
How & where do you build the bot when it snows and your robo-base (school) is closed? Elgin Clock General Forum 28 03-03-2008 00:12
paper: Control an FRC bot with a Wiimote Greg Marra Extra Discussion 8 21-01-2008 12:41
1189 - Human-Bot Arm Control jmcr8on Robot Showcase 50 13-10-2007 22:58
