Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 11-06-2010, 15:04
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Straberrie will become famous soon enough
Setting Max Speed?
Hey!
My team is using a four-wheeled holonomic drive. We are using four Victors.
RobotDrive myRobot;
Victor VictorFrontLeft;
Victor Victor RearLeft;
Victor VictorFrontRight;
Victor VictorRearRight;
Joystick Joystick;
myRobot(4,1,3,2);
Joystick(3);
VictorFrontLeft (4),
VictorRearLeft (1),
VictorFrontRight(3),
VictorRearRIght (2)
In Operated Control:
myRobot.HolonomicDrive( Joystick.GetMagnitude (), JoyStick.GetDirectionDegrees (), JoyStick.GetTwist());
The drive itself works. I attempted using:
myRobot.SetLeftRightMotorSpeeds (0.1, 0.1);
to set max speed that Victors can operate the motors at so that the drive would be more controllable, but it didn't work.
How would I set max speed of a Victor?
Thank you very much!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 11-06-2010, 15:38
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Setting Max Speed?
Gear down your motors more, clearly this is a mechanical problem from a competition standpoint it would be better to utilize the higher pushing force and acceleration that are gained by gearing the motors to a higher reduction.
Alternatively you could try scaling the output to each victor by a constant, like 0.8, and/or add an if statement that caps the maximum speed sent to each victor.
Unread 11-06-2010, 15:51
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Your code may be working fine. I know that we tried something similar in LabVIEW with Jaguars. Our only problem was that the wheels (attached to CIMs) wouldn't turn at any noticeable speed until we set the speed to at least .2. Try increasing your maximum speed by increments of .05, it worked for us.
Unread 11-06-2010, 16:00
Straberrie's Avatar
The Plague
AKA: Rebecca
Thank you! lol I cant believe it was this simple >< I feel a lil stupid lol
We just did it and it workedddd! Thanks againn
Unread 11-06-2010, 16:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Good deal
Don't worry, my team's programmers get lost on the simple things too
Unread 11-06-2010, 17:48
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Not to point out the obvious, but if you actually tried setting the max victor speed to .1, this would be 10%. This is wayyyyyyy too little power to do anything. .5-.6 would be a far more reasonable limit to start with, especially for a holonomic drive with potentially quite a bit of resistance.
Setting the speed on a jaguar in C++ DillonMartine Programming 3 01-02-2009 11:26
Brake/Coast setting for speed controller cabbagekid2 Control System 0 16-02-2005 16:54
Brake/Coast setting for speed controller cabbagekid2 Electrical 0 16-02-2005 16:54
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
