Go to Post There are few things I hate more in life than electrical tape residue. - AdamHeard [more]
Unread 13-06-2010, 09:57
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Mill or Lathe...
Well my team has sets it's fundraising goals, and one of them is to increase the functionality of our small machine shop. Right now our shop contains:
-Benchtop Drillpress
-Freestanding Drillpress
-Miter saw
-Bench Grinder
-Bandsaw
-Files... Many Files
So my question is if we have to decide between a mill or a lathe, which do you feel is better for a robotics team. I am not an educated enough machinist to know the full capabilities of either machine so i would love to hear people's reasoning.
Unread 13-06-2010, 11:40
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: Mill or Lathe...
-Miter saw
-Bench Grinder
-Bandsaw
Do you have access to any other machines such as a water-jet? If you do, that plays a large role in this decision.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 13-06-2010, 11:45
Jee Jee is offline
FRC #2085 (Robodogs)
Jee is an unknown quantity at this point
If your team has way too much money, I would suggest a CNC Machine. It uses a computer to control servos and motors and mills according to the CAD drawing you give it. This is how teams go about getting their delicious chasis.
If you don't feel like spending $30,000 go with a combo mill/lathe.
Our team uses a Smithy 3-in-1. It works extremely well and is good for almost every job (custom shafts, rings for clips, milling swerve drive modules).
Unread 13-06-2010, 11:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Nothing beats a lathe for all around usefulness. Something with 9-12" swing and at least 20" between centers is plenty big.
Unread 13-06-2010, 12:05
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
It depends on how precise you want to be. Right now you can't do anything with cylindrical objects. Your shop right now can drill holes. If you need slots, holes drilled with precision, counter bores etc more than working with cylinders, get a mill. If you are happy with being able to drill holes and such with your drill press and don't need the extra functions of a mill, then get a lathe.
If you really want a complete shop, you should see if you can find a way to get both. Maybe just get some smaller cheaper stuff for starters, or you can see if you can get discounts or possibly something for free.
Look around for companies that switched to CNC's not long ago. My team went to a company that had a lot of old manual machines that they weren't using and we got a mill and a lathe for free. (of course it wasn't quite that easy, but take a look around, a lot of companies are probably willing to help).
Unread 13-06-2010, 13:09
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Go with a mill. I have seen machinists put round stock in a collet (not the same collet used for mill tooling) and put a lathe tool in a vice and essentially turn a mill into a lathe. One can also take a boring bar, flip the tool around, and do outside turning on a mill, in addition to simply using a boring bar to bore out round pieces. Sure a lathe will do any of these better, but a lathe cannot slot, cut angles, chamfer square edges, etc.
Unread 13-06-2010, 13:27
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Why not both?
Big One http://www.harborfreight.com/garage-...eed-44142.html
Small One http://www.harborfreight.com/garage-...hine-5980.html
Do note, depending on what your going to do with the machine this might not be a very good option. Your mostly limited to smaller workpieces and some what limited functionality (like you can't use both functions at the same time). Yet, it does come at a very nice price and fits in a much smaller space than separate machines. Yes I know the quality is somewhat poor and its not the most ridgid machine in the world, but for most robotics applications it will work fine.
So if your looking to machine small brackets, shafts, hubs, bolt circles, gearbox plates, and etc, this would do a fine job (given you have the right tooling).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 13-06-2010, 13:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I would highly recommend against the 3 in 1 machines. You get one machine that does 3 things poorly, instead of 1 machine that does 1 thing pretty well.
I'd recommend a lathe. I think we use ours more than our manual mill and our experience in the past has been that it's very easy to find machine shops to donate time to manufacture milled parts.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-06-2010, 14:06
CraigHickman
Posts: n/a
I would echo this. Specialized tools have been refined for a reason, and combining them only cripples each function.
Agreed on the lathe as well. If you have the ability to make holes (drills), making things to go in the holes (shafts, etc) is the next step.
Unread 13-06-2010, 14:30
Lowfategg's Avatar
AKA: Tyler Moser
I completely agree that its not ideal and that separate machines would do a much better job.
But if the question is only having one or the other (budget reasons), I much rather have the capability of doing simple mill operations along with simple turning operations, since its a whole lot better than not begin able to do anything.
Some teams aren't so lucky to find such machine shops because of location or other reasons.
Anyway, if I could only have one, I would get a good sized lathe first and then a mill after that (don't dis the usefulness of a milling machine, its a whole load better than a drill press). If you take the time to look around on craigslist or ebay you can sometimes find older machinery that will be well suited for robotics at pretty cheap prices. I got an older J-head Bridgeport for $500 along with a vise, beats any import machine that you could ever get for the money.
Unread 13-06-2010, 14:36
AdamHeard's Avatar
Lead Mentor
I agree here.
I personally love milling much more than lathing; but if we had to choose one or the other, we'd have a nice lathe.
Unread 13-06-2010, 14:50
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
After thinking about this issue for a while, I realized that I almost never use our mill. For this reason alone, I'd say get a lathe. You can currently print out a hole pattern sheet and glue it on to your metal to make your chassis with a drill press or even a hand drill. With a lathe, you'd be able to make so much more.
Unread 13-06-2010, 15:42
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
I'd say it really depends on the type of team you are, and how you guys usually make your bots. If you find yourself doing complex cuts a lot, then get a milling machine, if you make custom drive trains, axles, or round things, lathe.
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 13-06-2010, 17:24
Chris is me's Avatar
AKA: Pinecone
I would figure out what you can get done around you, via other teams or otherwise, before making a decision. Maybe your sister team or friend down the street has a lathe which will make the decision easy.
Given one or the other, I would rather have a lathe. I've had stuff made on a lathe a lot more than on a mill. When you consider how many standoffs, spacers, shafts, and other turned parts you have on your robot, it's pretty clear the lathe gets a ton of use. How else do you put in your snap rings anyway?
Stuff like lightening patterns that you'd mill can be done (albeit less efficiently) with a drill press and round holes. I don't think I milled anything in 2009 (we had our ball tower routed with a laser cut guide, though, which would have been much harder and more time consuming with a drill press). This year, Shaker had its chassis CNC milled, but if we didn't have access to mills we could have gotten away with C-Channel or something.
Unread 13-06-2010, 17:31
DonRotolo's Avatar
Back to humble
FRC #0832
Lathe.
We've used our lathe every year since we started.
We have access to a mill, and have never used it.
Advanced tools in the workshop (Mill, Lathe, Welder etc.) Leav Technical Discussion 18 29-03-2010 12:37
Drill/Mill or Lathe/Mill attachment for small shop area Coach Norm General Forum 22 16-09-2009 15:59
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Good deal on a lathe? sanddrag Technical Discussion 7 25-02-2005 23:02
Grizzly Lathe Opinons Caroline General Forum 7 28-08-2002 18:55
