Go to Post it would be a sign you do too much robotics when you find toolpaths sexy. - Aren_Hill [more]
Unread 13-06-2010, 16:28
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Arcade Drive Troubles in Autonomous
Hi all,
I'm almost done with reprogramming this year's robot in C++ instead of LabVIEW. The only thing holding me back from marking it done is the autonomous.
In autonomous I'm telling the robot to go forward like so:
static const float autonomousForwardPower = -0.5;
//Move forward!
drivetrain->ArcadeDrive(autonomousForwardPower, 0.0);
Same exact drivetrain I use for teleop. I even use the function in teleop. Though it seems no matter what I do the robot turns left at full speed instead of going straight.
I even tried it in teleop and it does the same thing.
So, yeah - I'm confused why this is happening. Thoughts?
-Tanner
Unread 13-06-2010, 16:40
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Arcade Drive Troubles in Autonomous
Have you checked the hardware? Does it work if you re-load the LabVIEW code?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 13-06-2010, 16:46
Tanner's Avatar
Hardware is fine as far as I know. Like it drives in teleop fine.
In teleop the code is:
//Drive the robot
drivetrain->ArcadeDrive(driverJoystick->GetRawAxis(4),driverJoystick->GetRawAxis(2));
Which works perfectly fine. The robot drives straight and turns where I want it to.
The LabVIEW code would probably work if I hadn't lost my flash drive with it on it.
-Tanner
Unread 13-06-2010, 17:34
Are you using Simple Robot or Iterative Robot ?
What other code do you have in autonomous besides what you posted ?
Unread 13-06-2010, 17:41
Tanner's Avatar
Iterative.
void AutonomousContinuous(void) {
	printf("Running in autonomous continuous...\n");
	GetWatchdog().Feed();
	if (kicker->HasBall())
		//We have a ball, thus stop moving and kick the ball
		drivetrain->Drive(0.0, 0.0);
		kicker->SetKickerMode(KICKER_MODE_KICK);
	} else {
		//We do not have a ball
		if (kicker->IsKickerInPosition())
			//Move forward!
		} else {
			//If not in position, wait for it to be there...
			drivetrain->ArcadeDrive(0.0, 0.0);
			kicker->SetKickerMode(KICKER_MODE_ARM);
	//Run the kicker
	kicker->Act();
-Tanner
Unread 13-06-2010, 18:18
Save what you've got, then get rid of everything in autonomous except
...and see if it drives properly.
If it does, then you've got a weird problem somewhere else in your code. Like for example, are you protecting kicker->Act(); from re-entering?
Edit: I just saw your other post. Uncontrolled re-entry could cause a stack overflow and crash your code.
Unread 13-06-2010, 18:40
Tanner's Avatar
Protecting kicker->Act(); from re-entering? Sorry, but what do you mean by that? I've never heard of that.
-Tanner
Unread 13-06-2010, 18:44
AKA: Ian Thompson
re-entering is when a function is called again before it finishes being called the first time. The variables in your kicker object may not be in a clean state for the second call, causing a crash
Unread 13-06-2010, 18:54
Tanner's Avatar
Ah. How would one prevent this?
I think though re-entering has more to do with the robot crashing than the robot not being able to drive straight from arcadeDrive(). Unless they're somehow weirdly related and the kicker is affecting the drivetrain.
-Tanner
Unread 13-06-2010, 18:58
-Tanner
You are running AutonomousContinuous, which means the cRIO is repeatedly running your autonomous code as fast as it possibly can. You are calling the kicker->Act() method each time. I haven't seen the rest of your code; if there's another concurrent thread which also calls kicker->Act() it might cause a problem.
Removing everything except
and testing to see if that fixes the problem is a quick way to help pinpoint the problem.
Unread 13-06-2010, 19:01
That's why you should remove all the code except
and see if it fixes the problem.
Unread 13-06-2010, 19:12
Tanner's Avatar
I'll have to see tomorrow as I'm done with the robot for today.
I'm not sure how I would rethink to fix this. How would I protect the function from reentry? A google search on the topic didn't bring up anything other than NASA links.
-Tanner
Unread 13-06-2010, 19:21
It's pretty easy. Here's some pseudocode:
Declare a static boolean within the method, say "kicker_busy".
if kicker_busy exit;
kicker_busy=1;
// put your code here.  It's now protected from re-entry.
kicker_busy=0;
//return
But before you do that, please see what happens when you remove everything except
Unread 13-06-2010, 19:23
Tanner's Avatar
<CODE>
Ah. That seems pretty simple. I was so over thinking it.
I'll take a look at that tomorrow and then get back.
Thanks for the help.
-Tanner
Unread 13-06-2010, 20:01
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I suspect that your problem is that your RobotDrive class is not set up properly for the way your robot is wired (one side is either not inverted (using RobotDrive::SetInvertedMotor()), or inverted when it shouldn't be).
It's probably just working in teleop mode by lucky coincidence, because your joystick setup looks strange - you're feeding what seems to be the twist axis (4) into the moveValue parameter of ArcadeDrive, and the Y-axis (2) into the rotateValue parameter.
I doubt the non-reentrancy of your kicker function is the issue, because non-reentrant functions only cause problems when they're called more than once at the same time (i.e. by different threads), and I'm pretty sure all the Periodic/Continuous methods in IterativeRobot execute in the same thread.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Semi-Omni-Arcade Drive byteit101 Programming 20 24-01-2010 08:21
Programming Arcade Drive kyungjin C/C++ 4 06-04-2009 11:28
Non-Arcade Drive causes problems in Autonomous... pinballwizard96 NI LabVIEW 2 01-02-2009 20:45
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Arcade Drive Anfony VEX 4 08-11-2006 19:46
