Go to Post 321 didn't get picked up today because the front desk of the high school wouldn't let him in! Thank goodness the FedEx driver was nice enough to come back and get it for us! - Chuck Glick [more]
Unread 13-06-2010, 17:05
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Robot Crash
Hi all,
Working on alternate ideas while doing the whole reprogramming the robot in C++.
The robot works fine until I press the kick/fire button, upon which the cRIO "crashes". Nothing happens, DS says "Watchdog Not Fed". Using NetConsole, I could see that the cRIO clearly crashed, but now it's not saying anything for some reason.
I reimaged the cRIO to see if that would fix it, but nope. Though it now says the evil errors:
data access
Exception current instruction address: 0x0215bf40
Machine Status Register:  0x0000b02
Data Access Register: 0x05000060
Condition Register: 0x42000242
Data storage interrupt Register: 0x40000000
Task: 0xe63170 "FRC_RobotTask"
0xe63170 (FRC_RobotTask): task 0xe96170 has had a failure and has been stopped.
0xe63170 (FRC_RobotTask): fatal kernel task-level exception!
If I comment out line #71 in Kicker.cpp and then push the fire/arm button, the robot stops doing what it does, the DS indicates "Watchdog Not Fed" and nothing else is printed from NetConsole (not even disabled printf's).
I want to say it has something to do with the rollerEncoder because I'm not getting any data from it. Dad hasn't hooked up the scope yet to tell for sure though.
If you want to look at all the code, look here:
http://github.com/Tanner/Team-1261--.../rollerEncoder
Thoughts?
-Tanner
Unread 13-06-2010, 18:08
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Robot Crash
Can you put printfs every few lines to narrow down the location of the crash?
Oh and we have dead encoders on our bot and nothing went wrong when we tried to use them. Unless you're encoders are somehow causing NULLs, you should be fine
Also, when looking at your code, I noticed that you call Kicker::Act in autonomous, which looks at joystick buttons. The DS will send whatever data was on the DS at the beginning of Autonomous, so if one of the control buttons are pressed when auton enables your kicker code will follow it
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 13-06-2010, 18:49
Tanner's Avatar
Re: Robot Crash
I can do that tomorrow afternoon and get results back to you then.
Ah, that's good to know.
All though that should (hopefully) never happen, I should fix that. Thanks for noticing.
-Tanner
Unread 13-06-2010, 20:09
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Robot Crash
In my experience, the most common source of those symptoms (crash, "Watchdog Not Fed" message) is when your code tries to dereference a null pointer. I'd suggest doing a quick check to make sure you're creating all the objects you are using.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 13-06-2010, 21:11
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Robot Crash
Just quickly looking through your code I notice that you never initialize variable kickerSwitch
That would be a null pointer at at line 94 / 95 (The number spacing is off a lot, I can't tell)
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 14-06-2010, 11:42
Tanner's Avatar
Re: Robot Crash
Hmf. I don't do I. I removed it in the last commit for some reason (grr @ last commit).
I commited it back. Will see how it all works when I get off work.
-Tanner
Unread 16-06-2010, 15:53
Tanner's Avatar
Re: Robot Crash
The variable kickerSwitch was it. Not sure why I removed it, but that was it. At least it wasn't something terribly wrong.
Thanks all!
-Tanner
Laptop crash mjcoss C/C++ 2 14-04-2009 12:10
HELP: Robot Crash in Autonomous Shadow503 C/C++ 6 23-03-2009 00:33
PlasmaCam Crash Course Andrew Blair Technical Discussion 0 30-12-2005 21:48
Prom Night Crash Nate Edwards General Forum 5 28-05-2005 15:15
3dsmax5 Crash? yangotang Inventor 5 09-03-2003 21:17
