Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 13-06-2010, 19:12
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Arcade Drive Troubles in Autonomous
That's why you should remove all the code except
drivetrain->ArcadeDrive(autonomousForwardPower, 0.0);
and see if it fixes the problem.
I'll have to see tomorrow as I'm done with the robot for today.
I'm not sure how I would rethink to fix this. How would I protect the function from reentry? A google search on the topic didn't bring up anything other than NASA links.
-Tanner
Semi-Omni-Arcade Drive byteit101 Programming 20 24-01-2010 08:21
Programming Arcade Drive kyungjin C/C++ 4 06-04-2009 11:28
Non-Arcade Drive causes problems in Autonomous... pinballwizard96 NI LabVIEW 2 01-02-2009 20:45
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Arcade Drive Anfony VEX 4 08-11-2006 19:46
