Honey, will you tether your soul to mine?
Unread 14-06-2010, 10:33
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: Mill or Lathe...
Originally Posted by squirrel View Post
If you need to make gearboxes, and you're not very good at laying out and drilling the holes with a drill press or punch, then a mill can be very helpful. Boring holes for press fit bearings can be done with a lathe, in fact you can more easily control the size of the hole.
But it is also far harder to setup and hold a gearbox plate in a lathe with a faceplate or a 4 jaw (unless your skilled, and you have the right tooling). If you don't have either of those, your screwed. With a boring bar and a mill you can make holes of any size (within .0005) on any piece you can get on the bed.
A better solution might be to figure out how to design the gearbox so it can use looser fits, like AM does.
More like poor machining that can causes gears to wear and fail quicker. Also it adds a ton more friction.
The best answer to this thread: Just get both.
Btw, this was quite a good thread also on a similar subject: http://www.chiefdelphi.com/forums/sh...ad.php?t=85568
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Advanced tools in the workshop (Mill, Lathe, Welder etc.) Leav Technical Discussion 18 29-03-2010 12:37
Drill/Mill or Lathe/Mill attachment for small shop area Coach Norm General Forum 22 16-09-2009 15:59
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Good deal on a lathe? sanddrag Technical Discussion 7 25-02-2005 23:02
Grizzly Lathe Opinons Caroline General Forum 7 28-08-2002 18:55
