Go to Post Evolution is innovation. - Chris is me [more]
Unread 13-06-2010, 17:50
isaacdl isaacdl is offline
I have a white hat..it's just dirty
AKA: Isaac Dontje Lindell
FRC #3018 (Nordic Storm)
isaacdl is an unknown quantity at this point
using an IDE other than NetBeans for Java
I've got an older laptop (256mb RAM, 1.6ghz Pentium 4) that I kind of want to use as a programming laptop (so I have something to take to programming meetings and not always have to borrow one). However, it doesn't meet the minimum requirements to run NetBeans (I've tried anyway...those requirements are there for a reason ). Is there any other, leaner, IDE that I could use? I know there are other options, but is there a way to run/get the code on the cRio other than using NB?
I'm willing to run Windows or Linux, I'm bi-operating-system
thanks
Isaac
Unread 13-06-2010, 19:39
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Re: using an IDE other than NetBeans for Java
isaac,
I'm not sure what options you've chosen to add to the install, but netbeans (6.80) is able to run on a 7year old sony FRV31 laptop with win xp 512M ram and 1.6g cpu.
It takes about 90 sec to load but it responds as fast as i can type java code.
bruce
Unread 13-06-2010, 19:41
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
all you need is Ubuntu and to install netbeans and the stuff, you can then use your choice of editors to edit the robot code (go nano!) and build it with ant
Unread 13-06-2010, 19:48
B.Johnston:
As my post states, the laptop has 256mb of RAM. Not 512. As per the NetBeans system requirements, 512mb of RAM is required. I did attempt to use it, and while it would start, and I *could* write code, it was too slow to be usable. It could not even keep up with my typing (which is not supernaturally fast by any means).
Robototes2412:
How do I build with Ant? (I know it's how build parameters are passed, but how do I make an Ant script/use it?) And why do you say I should install Netbeans?
Unread 13-06-2010, 21:57
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
I know this probably isn't the answer you are looking for, but... You can use any editor, and compile with a very simple one-line batch file.
If you want the color coding, syntax checking, etc. that comes with a typical IDE; then follow the other folks' advice.
If you just want to modify or write a few lines of code and compile it along with other pre-existing code; just use any non-WYSIWYG editor, and the command line syntax that is explained in the Windows or Linux sections of this tutorial. http://java.sun.com/docs/books/tutor...ava/index.html
IDEs are fine things to use (I use NetBeans); but they are certainly not required.
Blake
PS: If there is some complicated magic that a NetBeans plug-in uses to xfer results into the cRIO, then my suggestion falls flat. If that step can also be accomplished with a command line or two in a batch file, then you are off to the races.
Unread 13-06-2010, 22:01
Blake
I don't absolutely need an IDE, but how would you recommend getting the code onto the cRio in a format that it'll run?
Unread 13-06-2010, 22:13
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Take a look at the PS I added to my post while you weren't looking
However, I am confident (I would bet a nice dinner but not a paycheck) that a very small handful of command line entries will accomplish the transfer.
Take a look at any log files the Netbeans method leaves behind, or open up (via Notepad/Wordpad) any built-in batches/scripts/macros to see what is happening under the covers. If you still can't find out what is going on behind the curtain, contact whoever supports the Java/cRIO code given to teams and/or put into NetBeans. Somebody will know how to do the transfer from a command line.
I have never worked with an FRC cRIO; but heck, it's just a computer. Hopefully what you FRC guys are using is just a bundling of standard methods with a tiny bit of NetBeans added-value wrapped around it.
Blake
Unread 13-06-2010, 22:33
I know for a fact that stuff is FTP'd onto the cRio, *but* I don't know what to put on there, or where to put it. Yeah, if no one else has any other ideas, I'll start looking for a FRC-connected person.
Unread 14-06-2010, 10:49
1 * 4 != 14
the FRC ant script is all that is needed, I use CLI to demonstrate programming to freshmen
Unread 14-06-2010, 11:10
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Have you tried eclipse? We used it at school this year and its free.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 14-06-2010, 11:47
I pretty much know that there are other IDE's now. What I need to know is how to get the code onto the cRio. How do I use the Ant script?
Also, if I where to use another IDE (or text editor for that matter), how do I make sure that when I turn it into a jar, the interpreter can find the WPILibJ stuff?
Unread 14-06-2010, 21:52
1 * 4 != 14
I am assuming you use linux in my demo
cd to your project directory
run this:
ant build deploy
it will build and deploy
Unread 14-06-2010, 22:42
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
$20 for a 1Gb RAM stick from Newegg will solve all these problems.
Art Dutra IV
世上无难事,只怕有心人.
Java Native Interface (For using code made in windriver) biojae Java 3 07-03-2010 22:46
NetBeans Java Debugger Connects once, but not again David Fort Java 3 20-02-2010 12:17
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Netbeans/Overall Java/Code help!!! a kenny03 Java 5 18-01-2010 22:32
Using a router other than WRT610N mgurgol General Forum 2 01-05-2009 16:50
