Go to Post The more time we spend there, and the more investment we have in the team, the more rewarding it is. - ILAMtitan [more]
Unread 14-06-2010, 15:27
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Computer Overheating
My macbook constantly overheats and I was wondering if you have any solutions. I was going to buy a cooling pad but I figured I'll post here first and look at alternatives. Could it be the fact that my room is already really hot? (i think that is because of the computers though) The computer gets so hot to the point I can barely touch it. What would you recommend?
Unread 14-06-2010, 17:55
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Computer Overheating
Download smcFanControl, and create a new profile with much higher fan speeds. I use this on both my iMac and my MBP, and they usually run at about 20C cooler now than on the previous Apple default settings.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-06-2010, 18:16
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Make sure your CPU heatsink and fans are not clogged up with dust and dirt. A little compressed air does a good job (be-careful of static electricity).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 14-06-2010, 19:36
kgzak's Avatar
AKA: Kris
I did that, I took my computer apart and cleaned out everything. I was careful and avoided static electricity, I was grounded.
Unread 14-06-2010, 19:37
kgzak's Avatar
AKA: Kris
I'll try this and see if it helps.
Unread 14-06-2010, 19:53
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
You can also try reapplying the thermal compound. Apple does a terrible job ad pretty much just lathers the heatsink with some cheap paste. My macbook was running hot so i cleaned up the inside and reapplied the thermal paste, I see about 10 degrees cooler temperatures. It still runs warm around 64 degrees Celsius browsing internet, using excel, and listening to music, and around 75 doing anything involving flash.
Unread 14-06-2010, 22:58
kgzak's Avatar
AKA: Kris
It has cooled it down by quite a bit.
I run a lot more than that at a time, which could be the cause of my overheating problem, I would reapply it if I had time, but right now I don't. Thanks for the info though. I think I need to get something to get more air to my computer. Right now it is sitting on a wooden desk surrounded but another computer to one side and a monitor to the other.
Unread 16-06-2010, 14:33
kgzak's Avatar
AKA: Kris
I have removed a computer from my desk which has allowed more airflow and cooled my macbook down, I think I am going to go look at a cooling pad to get even more airflow. I will also try reapplying the thermal compound. Thank you all for your help.
Computer Science or Computer Engineering? KRibordy College & University Education 14 09-10-2009 01:56
Compressor Overheating McGurky Pneumatics 6 29-08-2009 14:08
USB chicklet overheating kuelin Technical Discussion 5 19-12-2007 00:23
Cmucam overheating Oumonkey Programming 12 25-01-2007 17:49
Drill Motors....OVERHEATING, DRIVETRAINS! Brian48216 Motors 19 19-03-2003 10:18
