Go to Post It's only messy if you allow it to be. - Jay H 237 [more]
Unread 15-06-2010, 14:48
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Non-treaded wheels?
Annoyed after years of replacing treads that fall off, I've decided that there has to be a better way.
Does anyone know where I could find some "traction" wheels that do not have plaction-style treads? And that would also be easy to interface with AndyMark products(sprockets, etc..)
I've heard of colson wheels, but I also heard that they are not the easiest to use "out of the box"?
Preferrably non-pnuematic...
Thanks
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 15-06-2010, 15:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Non-treaded wheels?
http://www.andymark.biz/am-0420.html
You could try doubling, or even tripling these wheels together.
Maybe you should look at more effective ways of attaching the tread? The issue with getting a non-removable treaded wheel is that when the tread wears out the whole wheel is useless.
Unread 15-06-2010, 15:07
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
We at AndyMark are working on a new tread-attachment method, using conveyor belt lacing hardware. Here is a sneak peek. Later this summer, this method will be in place for all AndyMark Plaction Wheels.
Sincerely,
Andy Baker
Unread 15-06-2010, 15:08
gorrilla's Avatar
AKA: adam spears
I didn't mean non-removable exactly, I was pretty much referring to the am-KIT wheels,
I guess what I was wanting is a solid rubber type wheel like those but with stickier material?
Adam Spears
Unread 15-06-2010, 15:09
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Neither link seems to work.
Unread 15-06-2010, 15:16
Chris is me's Avatar
AKA: Pinecone
Thanks
If you throw out Colsons, I'd probably recommend some kind of polyurethane rubber wheel or something. Before FIRST I used to do a lot of tinkering with inline skate and scooter wheels, which had a lot of the same requirements as an FRC wheel with regards to shock loading, tread wear, traction, etc. They certainly would not work "out of the box", but you could probably get a company to install an aluminum core with a hex bore or a bolt pattern for you.
Not that I've used them on an FRC robot or anything, so no guarantees, but it's an idea I've wanted to try for a little while.
Unread 15-06-2010, 15:19
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Do you have access to any machining? I would try machining off the regular rubber tread, make a mold, and cast your own tread onto the plastic wheels. There are plenty of cheap rubber casting kits around. Try slotting (in cross-hatched patterns) or knurling the surface of the plastic wheel (with the tread gone) so that the cast-on tread gets a good, solid bite.
A buddy of mine in college made a great casting setup by machining the wheel's lug pattern into a plate, then boring out a two-part block (with the two halves already bolted together) to the tread diameter he wanted, then he bolted the blocks to the plate.
Unread 15-06-2010, 15:20
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Robot Market Place has several options. I have not used them, just pointing out they are there.
Unread 15-06-2010, 15:27
An ancient FRC trick: Take a Skyway wheel (similar to the AM KOP wheels of the current day), grind or sand off most of the tread, then screw on belting that is similar to the AM belting strips. When you need to replace said belting, unscrew the screws and grab a fresh piece of tread.
It's not exactly common for this setup to fall off mid-match--if one end comes loose, you will notice pretty quickly.
Unread 15-06-2010, 15:52
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
It's just like chain tensioning. If done correct the first time, you will not have any issues.
One of the main reasons that the tread has the ability to be taken on and off is reuse. You can reuse the wheels for as many competitions and years as you would like, just replace the tread.
Not so bad? These are shinny.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 15-06-2010, 15:58
gorrilla's Avatar
AKA: adam spears
Hmm, how well do those colson wheels work?
CoF?
Has anyone ever taken one of the kit wheels and cut a tread pattern into it?
Adam Spears
Unread 15-06-2010, 16:00
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Your treads fall off?
We've never had that problem and have been using belted wheels for 4 out of the last 5 years.
Are you using large head rivets?
Do you rivet too close to the end of the tread?
I'm curious what your failure method actually is.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 15-06-2010, 16:11
gorrilla's Avatar
AKA: adam spears
During build season we used 1/8th and 3/16th steel rivets, then during ship day and the FL regional the every single tread came off at least once, when one would fall off we would switch it out with a new tread and new rivets, the 3/16th rivets were large head.
The failure would happen when one of the ends would come loose then take the rest with it. Each end had two rivets, in between each spoke would also have two. Most of the time the rivets did not come out, the tread just tore a hole in the rubber around the rivet.
Adam Spears
Unread 15-06-2010, 16:37
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
This is odd. Do you use washers with your rivets?
We've never had tread really come off, just get so used that it was garbage. Our team also switched to blue nitrile tread and we haven't replaced the tread from our 2008 or 2010 robot. We have always used 1/8" aluminum Rivets.
I think the key is making sure to use rivets with washers so your rivet doesn't bore through the tread. Also making sure tread is cut to the correct length helps.
-RC
R.C.
MadTown Robotics Team 1323
Unread 15-06-2010, 16:41
FRC #1405
-RC
Might have also drilled the holes one size to large?
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
