Re: Hi-Fi Stereo FM Transmitter
For the FM bands, you can probably get away with it. A hacker EE can get all sorts of ugly to work (for some duration of work). But, why bother when the "right" solution is just as easy / affordable?
The first thing my RF mentor ever told me was "RF is the easiest of the EE disciplines as long as you do it right and don't screw up. Once you screw it up, thats when it becomes FM*". Basically, you don't want to add sources of error that are avoidable. The potential problem with a resistor + zener instead of a linear regulator is output impedence / load transients. In other words, the actual output voltage is now a function of its load. This effect can wreck the linearity of a system, and cause distortion. Imagine an output amplifier that is supposed to double the input. That is, out = in * 2. For most RF amps, what it actually is doing is out = in * constant * power_rail. If power_rail depends on out, you get something on the order of out = in * constant * power_rail + in^2 * other_constant. This usually isn't a problem with slower amplifiers, but those will still have a power supply rejection ratio that isn't perfect. This is partially why RF circuits have way more bypass capacitance than usual and why so much effort is put into ensuring the integrity of power and especially ground. *FM actually stands for "freaking magic", not "frequency modulation". This describes both how FM radios operate, and the occult chicken sacrifices necessary to make an EMI problem go away. |
My understanding of FCC regulations on low power FM is that you are allowed to transmit up to 200 meters without needing a license. Again, this is just my understanding from third party sources. |
Mr. Bill,
The kit you bought is intended for very low output and so very short distances. It is a simple design but may be subject to input overload from your audio source. A couple of input pots would easily eliminate that problem. Since the output circuitry is very simple, it is unlikely there will be an efficient coupling to your antenna making the range even shorter. I think Bluetooth ranges and coverage is likely what you will find. When you wish to upgrade, take a look here... http://www.ramseyelectronics.com/hk/....asp?page=amfm I recently built an FM100B for the radio station here. Although it is likely an overkill for you, I really was impressed with the construction and coverage. Ramsey has been around for a while and I have built some of their Ham radio projects over the years. I don't have a problem with zener diode circuitry if properly designed. However, in this application, the zener may introduce significant additional noise that will degrade the transmitted audio. |
I must admit, CD has done it again. I asked and I received the type of information that will really help. Most of this type of help comes from experience and wisdom directly related to the subject!
I looked at the FM10C kit offered on that site Al, it looks as though the circuit is very close to the one in my kit. We will see how it turns out. I had already planned on adding a couple trim pots on the input if the need arose, so at least we are on the same page there. Quote:
Bill,
The kit is frequency agile so that the intent is to tune it to an used channel in your area. You may have to experiment to insure that your transmitter is not interfered with by an adjacent broadcaster. Because the distance is so small, make sure that the transmit antenna and receive antenna are parallel for best reception. I thought the Ramsey kit looked similar but did not see a schematic when I called up the manual. The IT department has been playing with my computer here at work and I am not sure where any of the apps are in terms of latest greatest revisions. I writing this in Safe mode since I cannot get the box to turn on in normal. "The Helpdesk will respond in one business hour of your request." If they are here... For those of you lurking out there, the $10K Don refers to is per day per violation. The FCC does not have a sense of humor. However, the majority of retail kits available meet FCC minimums if not modified or coupled to high gain antennas. |
Typo: He meant UNused channel
Sure they do, the gave ME a radio license! If you unwittingly violate the rules and seem really shocked and sorry and cooperative, they'll probably just make you sweat for a while. |
#7
OK, status update time. Short and sweet, it's finished and I'm going to run cables instead.
The circuit works, barely. I guess for a 10mW transmitter I shouldn't expect too much. No matter how accurately I tune it, all I can get is a mono signal. The "stereo" indicator never lights on any receiver, and I've tried several. I can get good "tuned" indication, just not stereo. Here are a couple pictures of the project and it's modifications. ![]() This is the circuit. The blue 50K pot replaces two resisters and allows adjustment of the MPX Mix. Originally there were two 27K resisters in place. The yellow wire going off to the left is a half wave length antenna. Here is a picture of the entire circuit. ![]() The small board with the two pots is both a 2.7 vdc. zener regulator and level adjustment circuit. (Thanks for the suggestion Al.) As you can see, this can be powered by Micro USB +5 vdc. source. All in all, it was good practice, but I am not satisfied with the result. So, either I drop a couple hundred $$ and by a better grade 25mW transmitter or I run cables. That is, unless someone here can tell me what the problem with this little beastie might be. |
#8
Play with a Belkin Tunecast.....they don't cost much
#9
Bill,
Does the transmitter light a stereo light on a receiver very close to the transmitter? If not, this is usually an indication that the 19 kHz pilot carrier is not functioning. If the receiver does not see the pilot it does not try to decode subcarrier. If the close in receiver does come on in stereo, the pilot injection may be too low. All of this is to prevent unwanted noise in receive when the signal to noise on the subcarrier is low. Thoughts were, a quiet mono signal was better than a noisy stereo. It may indicate that the 38 kHz crystal is defective. Last edited by Al Skierkiewicz : 06-07-2010 at 08:03. |
#10
Try a half-wave counterpoise: If your antenna goes 38" in one direction, connect a wire to Ground (right where it first hits the board) and run it 38" in the the other direction. The best signal will be at a right angle to that "dipole".
It's cheap and quick, and could double your signal strength or better. But try what Al said: If you can't get stereo from 6" away, there's a fault. I have built $25 FM kits which worked at 150 feet, no problem. |
#11
Don, I was thinking the same thing. In fact, I have a dipole antenna from a stereo receiver I was going to try just for kicks. I'll let you know what I figure out. |
| Need help with stereo switch box | Simon Strauss | Technical Discussion | 7 | 30-10-2006 08:21 |
| stereo vision system with OV7620 | steveg | Programming | 3 | 04-05-2006 12:40 |
| What reciever should I buy for my home stereo? | Ben Lauer | Chit-Chat | 4 | 19-12-2004 23:51 |
| Push Cart Stereo | WSDragonAlex | General Forum | 24 | 31-03-2004 01:07 |
