Re: Robot Rule R08 - what does it mean, and what should it mean?
I was a little confused by the rule. It prohibited drive chains under the rationale that metal even touching the ground was tractive force, but that didn't apply to smooth chassis rails like 254 and 1868. That particular Q&A threw me off.
I hear ya. In this case our team tried to think about the common sense part of it only - so we added skids with a polycarb shield so the chains couldn't contact the bump at all with the idea "yeah, chains on carpet bump edges = bad." However, when some folks started worrying about every possible smooth rail that could hit the field it got a little unnecessary.
In looking at the rule...
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the carpet may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed. The interpretation should be applied to "traction devices" and devices used to transmit power to those devices. I believe the intent is to prevent damage to the carpet surface and to prevent damage to the underlying floor. In some cases, the arena is setting up the field over basketball court, or composition rubber running surfaces. Robots that have moving metal in contact with the field can penetrate the carpet and the sub surface. In addition, robot parts that damage the carpet require repair between matches. This year has been one of those years that carpet became so damaged that many events played more on colored gaffer's tape repairs than on actual carpet. Many teams were surprised when refs and/or inspectors informed them of problems with their robot structure damaging carpet and the possibility of DQ should they fail to fix the problem. The need for low CG combined with the extreme angle of the bumps and ramps caused significant carpet damage throughout the season. |
I think the widespread allowance of teams to use rivits in attaching wheel treads disallows the interpretation of a ban on metal touching the carpet. While I conceed that some teams may recess the rivits to avoid this situation I doubt most do.
Al does a nice job with his interpretation tying back the the letter of the rule. Of course, I wouldn't expect any less of Al. |
Thanks, Mark. Teams that use rivets to attach tread to wheels get extra scrutiny from inspectors. If the rivets are small, buried in the tread material and between tread extrusions, they are usually allowed. Haphazard installation of rivets get suggestions on how to replace/repair in order to pass inspection. At least that is the theory.
Spoiler for those with a sense of humor:
Al, if this is the case do you happen to have pictures teams could use as guides in the future? (Knowing that this rule may change in said future.) |
#8
Kara,
I am not surprised, inspectors can do some serious looking when you think they are looking at something else. You would be surprised how much I can check out while a team is hooking up their driver's station and powering the robot. Andrew, Many teams use commercially available belting for tread. This belting is available through McMaster and has 'teeth' that are 3/16-1/4 long. If a small diameter rivet is used, the head can easily fit between these 'teeth' without danger to the floor. On other material it is possible to counter sink the belt since the substrate is as thick as the teeth. Again the rivet would never touch the carpet, even if the teeth were worn off. Many (most) teams also compress the substrate while inserting the rivet which is akin to counter sinking. All of these methods prevent 'traction' contact with the carpet and the possibility for damage is minimal. We are seeing less custom wheels now that there is commercially available wheels that are easy to obtain and designed specifically for driving on carpet. |
#9
I'm a referee, not an inspector. I would only be called upon to assist in interpreting the rule, not enforcing it. But in my opinion, the letter of the rule says no. The spirit of the rule, as explained by Andy, is that these laces would not be expected to damage the carpet. They are somewhat recessed, and if they do touch the carpet they do so with a smooth surface. Hopefully the letter of the rule can be changed to match the spirit of the rule. Especially given that sometimes rivets that hold on treads do touch the carpet, but without damage. |
#10
188 also used metal treads in 2002. In Woburn's case, they were made from slices of thin-section aluminum C-channel extrusions, screwed to a turned plywood core. Having played with those wheels, I think it's fair to say that with attention to detail, they're not going to automatically ruin the carpet. Rounded corners are a must—not just for the sake of the carpet, but also so that you don't dig in when turning. In fact, they've got the unusual feature of slipping very little on carpet in the direction of motion. This means that you can't spin your drivetrain so fast that you melt the patch of carpet below you when immobilized—compare that to conveyor belt treads which have been known to do exactly that (e.g. 188 in 2004 with some sort of wedgetop and a 6-motor drivetrain in high gear). It's not so good for your motors and your gearboxes, but it's actually better for the surface of the carpet in that circumstance. Also, because the screw heads are deeply recessed in the channels, it's harder to snag a loop of carpet and drag it with you. However, because the carpet isn't particularly well secured, all of that traction can stretch or detach the carpet from field elements. But this isn't a feature of metal wheels—it's a feature of high-traction wheels. Quote:
If I had my way, I'd probably phrase it something like this: <G?> [Disablement and point penalties for field or venue damage during gameplay.]Phrased as "feature" rather than "device", to emphasize that it's not necessarily the whole wheel that is the problem—probably just a part of it. "Substantial" is a carefully-chosen ambiguity—it could be defined with a force specification, or left to the officials' discretion; it also depends on the way that game pieces are held in that particular game. Game pieces are included here, because it's conceivable that a robot could use a game piece to enhance its traction. PENETRATING FEATURE – A ROBOT feature that, during GAMEPLAY, penetrates the entire thickness of intact PLAYING FIELD carpet, and/or abrades or otherwise damages the substrate supporting the PLAYING FIELD, even if not designed for that purpose. Also, a ROBOT feature likely to accomplish same.Note that traction feature defined only in terms of actual function; penetrating feature also defined in terms of likely effect, so as to make it effective at inspection (irrespective of whether the robot has been on the field). <R?> [Sharp edges rule with PENETRATING FEATURE ban to filter out obvious problems at inspection.]Note that this would apply to things that aren't designed for traction, but exert it anyway. Past events are included, so that if Redabot damages the field at the Magnolia regional (and it's not corrected, for whatever reason), the officials at the Championship can rely on that fact to impose the prohibition immediately. Last edited by Tristan Lall : 16-06-2010 at 16:29. |
#11
Tristan, you are THE MAN when it comes to this stuff. I would vote for you to get the FRC rules one month before the rest of us, just so you can sniff these things out. Your detailed work would save thousands of hours of anguish for the FIRST community. Sincerely, Andy |
| Philosophical and social meanings of robotics- what does it mean to you? | Misanthrope | Chit-Chat | 1 | 29-04-2008 21:50 |
| What does it mean? | Lilor | Programming | 3 | 12-02-2008 22:06 |
| So what does GP mean to you? | Billfred | General Forum | 30 | 19-04-2004 22:58 |
| What does <3 mean? | Kevin A | Chit-Chat | 18 | 15-07-2003 11:25 |
