Go to Post Well I have to admit, most of the people on our team are geeks. I think that it's a title of honor considering it might as well be "boss" or "head supervisor" or something along those lines. - Cyberguy34000 [more]
Unread 13-06-2010, 20:12
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Arcade Drive Troubles in Autonomous
Originally Posted by Pat Fairbank View Post
I suspect that your problem is that your RobotDrive class is not set up properly for the way your robot is wired (one side is either not inverted (using RobotDrive::SetInvertedMotor()), or inverted when it shouldn't be).
I'm not sure how that would work, cause then wouldn't teleop not drive correctly at all? There's only one way a drivetrain will correctly work, yeah (unless the joystick values are strange)?
It's probably just working in teleop mode by lucky coincidence, because your joystick setup looks strange - you're feeding what seems to be the twist axis (4) into the moveValue parameter of ArcadeDrive, and the Y-axis (2) into the rotateValue parameter.
Well, I'm not using the kit joysticks. I'm using two XBox 360 controllers, so the numbers don't exactly correspond to the names in the WPI library.
-Tanner
Unread 13-06-2010, 20:18
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Okay, that makes sense, then. If you haven't already, maybe you should check the outputs of those axes directly with printf statements to make sure they are doing what you think they are doing in terms of axis and polarity.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 13-06-2010, 20:32
I'm pretty sure all the Periodic/Continuous methods in IterativeRobot execute in the same thread.
Good point.
Unread 13-06-2010, 20:34
Tanner's Avatar
Yeah, I should do that. I kinda just took it directly from LabVIEW thinking that things would be the same, but you never really know. I'll write that down to check as well.
-Tanner
Unread 15-06-2010, 21:38
Tanner's Avatar
Haven't been able to get to the office to test on the robot. Worked overtime today.
Yeah...
-Tanner
Unread 16-06-2010, 12:46
Tanner's Avatar
Tested autonomous with just the drivetrain movement (i.e. - drivetrain->ArcadeDrive(autonomousForwardPower, 0.0);, and it still turns.
Didn't have time to test anything else (I was on my lunch break), but I will this afternoon. We're doing nothing at work today so I should be able to get off early.
-Tanner
Unread 16-06-2010, 14:01
Well it wasn't time wasted - you've eliminated an entire realm of possibilities and narrowed down the problem.
Try putting
drivetrain->ArcadeDrive(0.5, 0.0);
in TeleOp and see if it still turns there.
If so, maybe "0.0" doesn't mean "straight ahead".
Do a printf of the value you are feeding in when the 'bot is going straight ahead in TeleOp, and see if it is "0.0" or some other number.
Unread 16-06-2010, 15:44
Tanner's Avatar
I think the arguments for RobotDrive::ArcadeDrive are backwards somehow. Cause when I do drivetrain->ArcadeDrive(0.0, autonomousForwardPower); the robot goes forward, but when I do drivetrain->ArcadeDrive(autonomousForwardPower, 0.0); the robot turns left.
So, I checked the joystick numbers and the inversion of the drivetrain motors - they were totally wacky. The joysticks for the ArcadeDrive function were backwards and the inversion was programmed in that format, hence the robot worked, but everything was backward. Heh.
Autonomous drives in the right direction now (or rather it turns in the right direction...). All is well.
What did we learn? Never program the drivetrain with joysticks first and then do the inversions. Figure out what those values are, determine what they should be (positive or negative) or use magic numbers (like 1 and 0), then figure out the inversions.
Glad that is figured out. Now to see if it still crashes...
Thanks all!
-Tanner
Edit: And it doesn't crash with the updates, yay!
Semi-Omni-Arcade Drive byteit101 Programming 20 24-01-2010 08:21
Programming Arcade Drive kyungjin C/C++ 4 06-04-2009 11:28
Non-Arcade Drive causes problems in Autonomous... pinballwizard96 NI LabVIEW 2 01-02-2009 20:45
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Arcade Drive Anfony VEX 4 08-11-2006 19:46
