Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 18-06-2010, 12:32
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: AC/DC circuit breakers?
You probably ought to still use a fuse in the circuit, I've seen smoke caused by relatively small batteries!
Unread 18-06-2010, 15:02
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
What size?
on the topic of circuit breakers:
Generally speaking, should you buy a breaker rated for the current the system is rated for, or that trips at or before that current? (trip amps vs. rated amps)
Unread 18-06-2010, 15:27
MrForbes's Avatar
AKA: Jim
Breakers or fuses are usually sized to the wiring (at least they are in power distribution systems used in houses, cars, and FRC robots).
But you also don't want it to pop at any normal working loads.
As I said earlier, 18 gage wire and 10 amp fuse/breaker should be fine for your application.
Circuit Breakers Teammax Electrical 5 31-01-2009 14:15
Circuit breakers? k4r3n2 Electrical 7 28-01-2008 03:36
circuit breakers.... archiver 2001 2 23-06-2002 23:58
Circuit breakers archiver 2000 8 23-06-2002 23:30
Circuit Breakers ark_1230 Electrical 28 09-04-2002 23:16
