Go to Post Manual labor experience with engineering training is a powerful combination. - N7UJJ [more]
Unread 18-06-2010, 19:31
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
GUI: locating mouse on graph indicator
I'm working on another non-FRC project. The idea is that you can draw a waveform on a graph, and hear it played. However, instead of drawing a continuous curve, I figured it'd be easier to just select some points, and spline fit between them.
So, part of that involves converting the location of the mouse into the point on the graph, and that's where I'm having some trouble. It mostly works, but there's some scaling and offset issues.
I've attached the subVI and the testing VI.
NOTE:
If you do not understand control references, event structures, and property nodes, the code may be quite confusing.
EDIT: I forgot the attachement. Thanks Tanner.
-- Marshal Horn
Unread 18-06-2010, 20:40
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: GUI: locating mouse on graph indicator
No attachment is present.
-Tanner
Unread 19-06-2010, 14:00
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Looks like a) the coordinates for Plot Bounds are Panel-relative, rather than control-relative, so you're accounting for the control offset twice and b) since the mouse coordinate origin is at the top-left, the offset/scaling for the y-axis is reversed. The version I've attached seems to work.
--Ryan
FRC 766, 2015-, Mentor
Unread 19-06-2010, 19:24
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Thank you.
-- Marshal Horn
Final Data graph!!! Just take a peek!! Jedward45 Scouting 0 12-03-2010 22:21
how to graph joystick inputs as a function of time? Guopeter NI LabVIEW 2 09-02-2009 17:49
Locating Extra Motors ilustrus Motors 0 13-01-2006 16:41
Optical Mouse / Ball Mouse Clark Gilbert Chit-Chat 26 22-07-2004 13:17
Haas CNC Mill Graph Function P-Dog Technical Discussion 9 13-03-2004 23:45
