Re: Current Control
Yes, I have firmware version 91.
I fiddled with the sliders, but didn't really get anywhere. Your method of tuning is actually perfectly acceptable and common, and it's just an approximation of Ziegler-Nichols. However, the oscillation point seems to change on me as I change the setpoint, and that's rather puzzling. (When I have the setpoint at 1A, every P value seems to either cause oscillation, or no output at all.) |
Re: Current Control
I was driving a CIM, with a set point in the 4-10 amp range. I never tried driving it at just an amp. You might be hitting resolution limits - maximum current is somewhere in the 60+Amp range, I don't recall what one count translates to.
| closed-loop torque (current) wheel control for mecanum | Ether | Programming | 3 | 07-02-2010 00:54 |
| Current Sensors | maclaren | Electrical | 15 | 04-12-2007 15:21 |
| Current Events? | Pavan Dave | CD Forum Support | 1 | 18-04-2007 07:49 |
| Current Sensor | Joshua May | Programming | 6 | 12-02-2004 10:48 |
| Amperage or Current | Rob Colatutto | Electrical | 19 | 24-01-2003 21:16 |
