Go to Post If you don't manage weight from the beginning, weight will manage you at the end. - charrisTTI [more]
Unread 18-06-2010, 14:34
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
pic: Back of the battery charging station
Unread 18-06-2010, 14:36
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: pic: Back of the battery charging station
am i correct in understanding that those components mounted on the back are the battery chargers with just the plastic shell taken off? or did you remove/add more to the preexisting components of the chargers?
By the way, I love the idea. Definiatly showing it to my team.
"Don't worry, programming can fix it"
Unread 18-06-2010, 20:54
That's correct. There are two circuit boards in the Schumacher battery chargers - the ones you see in this picture, and smaller ones that contain the controls to adjust voltage and current. The only change we had to make was to extend the 5-pin ribbon cable between them so it can run from the back through to the front (as seen in this picture: http://www.chiefdelphi.com/forums/sh...hreadid=86130).
Unread 19-06-2010, 09:17
angelawence11's Avatar
angelawence11 angelawence11 is offline
FRC #0195 (Cyber Knights)
Team Role: CAD
angelawence11 is an unknown quantity at this point
Yes. I love it. We have a freshmen on our team who has been assigned thetask of designing new battery holders. Something like this could really help him out. ill be sending him the link. thanks for posting this!
pic: Battery Charging Station (571) CD47-Bot Extra Discussion 16 29-11-2012 14:08
pic: The Robettes Battery charging station Jon Stratis Extra Discussion 12 30-06-2010 21:13
pic: Side view of the Battery charging station Jon Stratis Extra Discussion 5 17-06-2010 21:36
Battery Charging station barstow Electrical 19 07-04-2009 17:16
571 Paragon Battery Charging Station Rick Technical Discussion 7 27-05-2004 17:14
