Go to Post It is a good idea to try to stand in another person's shoes and treat them as your equal. It's called respect. - Jaine Perotti [more]
Unread 15-06-2010, 16:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Non-treaded wheels?
Originally Posted by gorrilla View Post
Has anyone ever taken one of the kit wheels and cut a tread pattern into it?
We have in the past. It works great until the edges of the pattern wear off, which happens fairly quickly.
Unread 15-06-2010, 16:47
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Originally Posted by Andy Baker View Post
We at AndyMark are working on a new tread-attachment method, using conveyor belt lacing hardware.
How much does the lacing protrude? Would there be any risk of violating, for example:
Originally Posted by 2010 R08
Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments.
--Ryan
FRC 766, 2015-, Mentor
Unread 15-06-2010, 16:56
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by Alex Cormier View Post
Might have also drilled the holes one size to large?
True, I know that we did this for a couple of rivet holes and the rivets would just pop out freely.
-RC
R.C.
MadTown Robotics Team 1323
Unread 15-06-2010, 17:06
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
-RC
I don't think so, but it's possible.
Finally after I had replaced all of them I put some 3M-2part epoxy on the ends of each, that held them for the remainder of the regional.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 15-06-2010, 17:14
AdamHeard's Avatar
Lead Mentor
I've seen a lot of teams rivet too much. Two rivets side by side in 1" is not necessary, we've gotten away with 1 rivet centered on the 1" face on each end. If you "cut" the tread too much with holes, it gets weak and wants to start to break apart at the hole.
Unread 15-06-2010, 19:53
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The failure would happen when one of the ends would come loose then take the rest with it. Each end had two rivets, in between each spoke would also have two. Most of the time the rivets did not come out, the tread just tore a hole in the rubber around the rivet.
This sounds like the holes through the tread may have been too big. They need to be a very tight fit so you can barely get the rivet through it. The woven foundation of the conveyor belt tread is very tough and will not tear through if the hole is tight enough. And yes, large-head rivets are better. Our swerve drive put severe strain on our treads this year, but we have never had a single tread come loose when properly riveted.
Unread 15-06-2010, 20:10
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
We at AndyMark are working on a new tread-attachment method, using conveyor belt lacing hardware. Here is a sneak peek. Later this summer, this method will be in place for all AndyMark Plaction Wheels.
Sincerely,
Andy Baker
So how would these work with the "no metal on carpet" rule? Assuming that it stays that is.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 15-06-2010, 21:35
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Originally Posted by RyanCahoon View Post
How much does the lacing protrude? Would there be any risk of violating, for example: (R08)
--Ryan
ChrisH
The application process suggests that some of the tread is ground away so that the metal lacing does not stick above the tread. The lacing has smooth edges and does not help in gaining any traction. The sole purpose is to lace the ends of the tread together.
In my opinion, rule R08, is not a "no metal on carpet rule". I have heard that some inspectors call it as such, and they are incorrect (again, in my opinion). Rule R08 is there to not allow "traction devices" that are metal, to assist with gaining traction to a system.
In the little bit of area where these laces touch the ground, I predict that there is LESS traction than there would be if there was no lacing. These are smooth, rounded metal hardware items.
I hope this helps. If there are inspectors out there who believe that R08 is a "no metal on carpet" rule only, then maybe we need a whole 'nother thread to discuss this.
Andy B.
Unread 16-06-2010, 01:03
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Andy B.
And thus grounding wires are legal, but still, the tread is a traction device. Couldn't the laces be considered a surface feature of, or an attachment on, the tread?
Unread 16-06-2010, 01:23
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
My team screws the conveyor belting from McMaster onto the AM KOP wheels. We have found this to be a relatively cheap and simple alternative to plaction wheels.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 16-06-2010, 03:13
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Well, it sort of is: "Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments."
On the other hand, the rule is clumsily written on several levels (e.g. "shall not" isn't necessarily an imperative), it hasn't been (uniformly) enforced that way for practical reasons, and there's no point in phrasing it that way (because metal isn't inherently unsuitable for use on carpet).
That's one rule I'd especially like to have a kick at fixing, because it's been an annoyance for several years.
Unread 16-06-2010, 08:21
I agree, it definitely needs to be fixed.
The intent of this rule, if I understand it correctly, is to not allow metal treads, as on TechnoKats and Wildstang robots in 2002. Also, it is aimed at not allowing file cards, which were also made famous by Team Hammond in 2002, and then copied by many teams that same year.
Maybe this rule can be scrutinized to death so that no metal can ever touch the carpet, but I seriously think that is not the intent. As a member of one of the teams listed above who had something on their robot which resulted in this rule, I would hope to understand the intent.
What surprises me is that well-meaning people look at this rule and automatically think that it's a "no metal on carpet rule".
I will start a new thread. Sorry for hi-jacking this one.
Andy
Unread 16-06-2010, 10:44
harryji369's Avatar
harryji369 harryji369 is offline
Captian
AKA: Harry Indrataher
FRC #0369 (High Voltage)
harryji369 will become famous soon enough
Talking Re: Non-treaded wheels?
have you ever tried skyway wheels
you can get them here
http://skywaywheels.com/products_002.htm
Unread 16-06-2010, 16:39
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Sincerely,
Andy Baker
I actually like the current set up quite a bit.
Why?
Because I'm able to remove the rivets, then yank the tread out without removing the wheels to split them apart (our wheels were captured on both sides this year).
While the conveyor alligator clips would certainly work, I'd like it even better if it was a small metal detail screwed into the wheel with 2 screws that had teeth on either side that pinch it against the plastic.
Name:	End of tread clamp.JPG
Unread 22-06-2010, 00:15
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
We have also used plaction wheels, but after replacing the treads multiple times we drilled a couple of holes and riveted it. (Along with some contact cement) it works like a charm, treads never fell off again.
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
