Go to Post After all FIRST & CD are both places to learn everything. - popnbrown [more]
Unread 22-06-2010, 01:15
Chris is me's Avatar
AKA: Pinecone
Re: pic: sheet metal 6WD
The moment of intertia of the cross section is directly related to it's stiffness.
If you google, you'll see for a rectangle, the moment of inertia is 1/12bh^3 (base and height). Base being the side parallel to the axis the beam is being bent around.
So, a 5" tall .050" thick plate has an I = 1/12(5in)(.050in)^3 ~ 5x10^-5.
The same beam with two 1" flanges is that I plus the I of the two flanges. I = 1/12(.050)(1)^3= .004
So the beam with the two flanges has a total I of .004+.004+5x10^-5 ~.084.
.084 / (5x10^-5) ~150:1.
Even if I made a mistake in the math somewhere, this demonstrates the difference flanges make in design. I could go on for pages elaborating this, but it'd better to google and look yourself (key terms being beam, cross section, moment of inertia, etc...). You'll also then understand why I-beams are shaped the way they are.
I meant how much of a strength difference does cutting part of the flange out for the gearbox make? A poster said that it would be much stronger, and I wanted to know how much.
Unread 22-06-2010, 01:22
AdamHeard's Avatar
Lead Mentor
I totally misread your question then.
Similar concepts apply, just inverse. The beam is substantially weaker due to that flange removal. Depending on how the gearbox is attached, the gearbox itself could add a lot of support to the beam where material is removed.
Unread 22-06-2010, 01:52
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Great explanation
The loss of a continual flange will not only decrease the second moment of area, but will also "chase" the stresses to the ends of the flange.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 22-06-2010, 01:58
AKA: Pinecone
Originally Posted by 548swimmer View Post
Great explanation
The loss of a continual flange will no only decrease the second moment of area, but also "chase" the stresses to the ends of the flange.
If that's the case, what's your basis for saying it'd be okay to remove the bottom flange entirely?
Unread 22-06-2010, 02:07
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Different design. The flange I said would be okay to remove was the bottom external flange. The top external flange used to mount bumpers will working in tandem with a properly mounted plate should, depending on material thickness, provide more than adequate structural integrity. That's why I said you could most likely remove that flange.
Unread 22-06-2010, 02:37
AKA: Pinecone
Ah. Did you use any kind of analysis to come to this conclusion? I'm trying to learn all I can here.
Unread 22-06-2010, 09:15
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Not on this specific piece, though I re-designs our kicker plate (under roughly 300 lbf) to make it lighter and not deform. This was one of the things I frequently noticed.
This is with a continual .5 inch flange on the top and bottom, 100lbf, fixed constraints at the bolt holes.
http://picasaweb.google.com/11295163... 6928451693122
This with a 5 inch break in the top and bottom flanges, same load and constraints.
http://picasaweb.google.com/11295163... 6931950242546
Unread 22-06-2010, 15:06
AdamHeard's Avatar
Lead Mentor
Another way to strengthen a frame such as this is adequate attachment between the inner and outer drive plates. This combines them into a much larger, and much stronger beam (a ~3-4" tall I-Beam).
If you understand the basic concepts, you'll quickly see that rather trivial and easy changes in design can cause appreciable increases in strength.
Kajeeven, this isn't a criticism of your design, I would definitely classify your attachment as adequate. It's just a convenient place to mention such concepts... Too much what on this forum and not enough why.
I do highly recommend adding a single baseplate that attaches to all members of the frame, or at least the full length of the front/back crossmembers and inner drive rails. This will greatly increase the rigidity of your frame. Think of it as an infinite amount of crossupports, providing strength in whatever direction is needed at the moment. Also provides a very low CG friendly electronics mount.
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: Sheet Metal Drivetrain Jacob Paikoff Extra Discussion 14 30-04-2010 11:21
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
New Sheet Metal Pattern Query easydub Inventor 4 13-07-2006 13:55
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
