Go to Post I just turned 51 and I'm still not sure what I want to be when I grow up! - Mike Betts [more]
Unread 20-06-2010, 22:50
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
pic: sheet metal 6WD
Unread 20-06-2010, 22:51
Chris is me's Avatar
AKA: Pinecone
Re: pic: sheet metal 6WD
Looks familiar.
Any reason not to make the bottom a full belly pan for electronics, etc?
Unread 20-06-2010, 23:05
MWB's Avatar
MWB MWB is offline
Building and building.
AKA: Marcus W. Byrd
FRC #3716 (WABots)
MWB is just really niceMWB is just really niceMWB is just really niceMWB is just really nice
Send a message via AIM to MWB
Is there any way to rotate the shifters so that the motors line up, for ascetics and very insignificant COG changes?
Marcus W. Byrd
Team 3716
Lead CAD/Design and Fabrication.
Unread 20-06-2010, 23:39
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
1. I would recommend a center divider on one side of the motors. It will add strength and also a place to mount an electronics tray (e.g. from the back to the middle with the front open, or something like that)
2. Electronics tray could be perforated aluminum. Just cut it to size, rivet it in, and zip tie the electronics. Nice and easy.
3. I like the chain tensioning method. Super simple. If you want, you could put a 1" tall by 1/4" thick block with a hole for the axle, then tap the end for a 10-24 (or 10-32 if you want) and just tighten the screw to tension it, then tighten the axle bolts to hold everything secure.
4. Are you using servos for the SS's? If you are using pneumatics elsewhere on the robot (or even if you aren't), pneumatics will shift easier then the servos. I do not know how much better they are, but they provide a lot more force to shift then the servo does. We always shift with pneumatics when using AM shifters.
5. Rivets. If you are waterjetting or otherwise CNC'ing the sheet metal plates, just add a few holes per connection and pop rivet it. Easier to assembly, and not much more work in CAD (this is especially true with a pneumatic riveter, those are great)
6. Have you done any math on the speed and gear ratios?
7. .125" seems really really thick. We use something around .050 in our chassis, with a plate around the axles (a little circle with an axle hole and 4 rivet holes, around 1.5" in diameter), or the above mentioned tensioning block with some reinforcement.
Kettering Motorsports
Unread 21-06-2010, 00:10
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
.125 sheet is way to thick, especially with flanges. You can easily go down to .09 (a fairly standard size) wihout too many design changes. Any thinner (.05) and I'd make larger flanges just to be on the safe side.
Is there any reason you're lightening with circles instead of triangles?
Is there any reason you rendered it as an illustration?
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 21-06-2010, 00:40
Depending on what manufacturing process they have available, circles are great to use.
Check out pictures of 228's recent robots.
Unread 21-06-2010, 00:50
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
True, I tend to forget about punches since we don't have access to one.
What about flipping the inner plate around so the flange is on the wheel side. It looks like the flange is small enough such that this wouldn't limit access too drastically, and having a flange along the entire length will be muh stronger.
Unread 21-06-2010, 01:01
If you have access to a punch, kajeevan, I would recommend checking out Art Dutra's white papers here on CD. He posted his CAD files and he has some awesome designs in there.
Unread 21-06-2010, 01:12
AKA: Pinecone
How much is "much"?
Unread 21-06-2010, 01:34
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Thanks!
I'm sure sure of the rational behind their choice of sheet metal direction flanges, but since the flange profiles look identical to the ones on our 4WD/6WD sheet metal designs, here's the rationality behind ours. The black flanges are our chosen sheet metal flange profile.
By putting the flanges where they are to avoid geometry conflicts, the necessary space between two chassis rails is kept to a minimum. These aren't the most optimal flange configurations for chassis strength, but they work good enough for our applications.
Art Dutra IV
世上无难事,只怕有心人.
Unread 21-06-2010, 23:49
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Originally Posted by artdutra04 View Post
Thanks!
Fair enough. I usually think of a flange's strength benefits instead of its mounting benefits. Although, with roughly 5 inches of pool noodle and 1.5 inches of plywood between colliding robots, the bottom flange may not even be necessary.
Unread 22-06-2010, 01:06
AdamHeard's Avatar
Lead Mentor
Originally Posted by Chris is me View Post
How much is "much"?
The moment of intertia of the cross section is directly related to it's stiffness.
If you google, you'll see for a rectangle, the moment of inertia is 1/12bh^3 (base and height). Base being the side parallel to the axis the beam is being bent around.
So, a 5" tall .050" thick plate has an I = 1/12(5in)(.050in)^3 ~ 5x10^-5.
The same beam with two 1" flanges is that I plus the I of the two flanges. I = 1/12(.050)(1)^3= .004
So the beam with the two flanges has a total I of .004+.004+5x10^-5 ~.084.
.084 / (5x10^-5) ~150:1.
Even if I made a mistake in the math somewhere, this demonstrates the difference flanges make in design. I could go on for pages elaborating this, but it'd better to google and look yourself (key terms being beam, cross section, moment of inertia, etc...). You'll also then understand why I-beams are shaped the way they are.
Unread 22-06-2010, 01:15
AKA: Pinecone
I meant how much of a strength difference does cutting part of the flange out for the gearbox make? A poster said that it would be much stronger, and I wanted to know how much.
Unread 22-06-2010, 01:22
AdamHeard's Avatar
Lead Mentor
I totally misread your question then.
Similar concepts apply, just inverse. The beam is substantially weaker due to that flange removal. Depending on how the gearbox is attached, the gearbox itself could add a lot of support to the beam where material is removed.
Unread 22-06-2010, 01:51
AKA: Pinecone
delete please.
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: Sheet Metal Drivetrain Jacob Paikoff Extra Discussion 14 30-04-2010 11:21
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
New Sheet Metal Pattern Query easydub Inventor 4 13-07-2006 13:55
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
