Go to Post Well I guess that's better than some teams idea of team bonding which would be taping a wayward freshman to the wall with duct tape. - Koko Ed [more]
Unread 05-10-2002, 15:59
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
It's the Toshiba Satellite 5105-S501. You can check it yourself if you want. It's got bluetooth, IrDA, USB, FireWire, and Ethernet, but no serial or parallel ports.
In case it helps, the adapter I tried (unsuccessfully) to use was a Belkin USB PDA Adapter.
Jeff Waegelin
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
serial communication using c++ Malakili Programming 31 01-05-2002 15:51
