Go to Post We figured it out. - benjiengi [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 13-06-2010, 00:55
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: golf cart steering
what about an arm or arms directly attached or geared to the steering wheel that allow it to be controlled by moving one's knee from side to side.
a Y shaped bar that straddles one's knee is both cheap and effective gearing could be used to amplify inputs, since a direct connection wouldn't be very agile without having to lift your knee, and then you wouldn't be able to operate the pedals.
Unread 13-06-2010, 09:26
Dick Linn's Avatar
no team (Synergy)
I'm the one who steered Cliff to this site, so let's do what we can to help out. I'm sending Cliff the contact info for Patty Cook, who can no doubt hook him up with some of the team contact info.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 14-06-2010, 08:04
cg285 cg285 is offline
cg285 is an unknown quantity at this point
Originally Posted by Don Rotolo View Post
OK, so do we find you a team in Orlando, a team in Va Beach, or both?
Also, before we start: We are a bunch of practical guys, some engineers, some not, and a LOT of High School kids, here on this forum. You and your son need to be the final deciders if something is safe or not.
OK, let's understand the problem: He has some use of his legs, but not his arms or hands. That means to me that he can use throttle and brake, but not steer. Is that right? yes, correct
Going on that assumption, if the right foot is go/stop, the left foot needs to be steering.
Problem #1: How does the left foot control steering. That is, does one use a gas pedal type control (press for right, pull for left) or a side-to-side lever? I would hesitate for a push/pull arrangement, since a big bump could cause an inadvertent turn. But, think about your son's capabilities and let us know what you think. he is capable of most anything
Problem #2: OK, we have some kind of input, how to we physically move the steering wheel?
A linear actuator directly on the steering box sounds nice, but as you said most are really not suited for that - but check McMaster.com and Google for other styles that might be workable.
Pneumatics are right out, since they can't hold a given position (Air compresses)
Hydraulics are fine, but need a pump for pressure and some plumbing. You don't need a lot of power (= thin cylinder, maybe 1" or so), but the controlling is pure mechanical.
Any of the above require a permanent modification of the cart, and people without a special skill can't drive it easily.
Another idea is to install a sprocket onto the steering wheel, and use a motor to turn it via chain drive. Make a method of de-energizing the motor and anyone can steer it. Electronic controls are light and cheap. I like this idea the most so far. this was my first idea but i think it would have to be a geared head motor
For a motor, look for a large servo motor. A servo motor is a special motor that provides feedback for its exact position. Using some basic electronics you can command it to, say, 7.2 degrees right and it'll go and stay there. The controls can take several forms, so as he improves different control schemes can be considered, not just a lever at his left foot.
Thinking off topic a little, he might even be able to control this with his head - turn right to steer right, and so on. Does he have good control of his neck?
OK, enough speculating for now. Let us know about #1.
Oh yes, we also need to know a little about you: Your experience, skills, machining capabilities, and budget.
i can deal w/anything mechanical inc fab & machine. i'm just back online from the weekend and am absorbing the posts. i'm going to investigate the tricycle thing. the boy might not like it but sounds intriguing to me (work on lower body while commuting). his idea for a golf cart is because he already has one. thanks for the ideas, cliff
Unread 16-06-2010, 22:25
DonRotolo's Avatar
Back to humble
FRC #0832
I agree, if there's a way to get him some aerobic exercise in the deal, it's good. But we don't want to tire him out just yet.
Instead of complex electric motors, sensors and and chains and stuff, maybe just a linkage between a foot plate for steering and the original steering shaft. Left foot steers, right foot gas/brake. Simple is usually best.
Let us know how we can help.
Unread 22-06-2010, 12:45
well the aerobic thing is out as i found out he has no sweat glands (only on his butt which didn't get burnt) and has to monitor temp always.
looked @ the cart this weekend. 3turns lock to lock, using a rack/pinion connected to a bell crank. not alot of effort to turn.
my thinking is a linear actuater connected to the bellcrank would be real easy but the duty cycle and the fact that it would not be easily converted back to manual operation is a concern
coming from an automotive background i thought about splitting the mast jacket, adding a sprockett to the strg shaft, sandwiched between 2 collars and a chain drive to a wiper motor or window motor. bushing the driven sprockett and securing with a removable pin or a gear dog. that way it's easy to change for normal steering.
fab a footpedal w/springs and stops to control range and effort. weld 2 pieces of bar stock forward and aft of center to operate a windlass sw (reversing sw)
other issues:
old style dimmer sw mounted on firewall (w/lighted indicator) for on/off.
makeup for/reverse arm, hanging down w/handle for leg control
lengthen the existing rail on driver side of seat and adding a safety net from rail to roof (driver unable to fasten seat belt, etc) enter from pass side
what do you think, too easy?
Unread 22-06-2010, 20:52
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The wiper and window motors we use (denso) do not have the torque to steer the vehicle. In addition, they are not built for continuos cycle and at high torques will trip out their internal thermal breaker. They don't have the rotational speed you would need to gear them down far enough and still have responsive steering. They also aren't terribly robust - they strip their worm gear out fairly easily.
Perhaps you could use one of our inexpensive "cim" motors which are quite powerful, durable, and inexpensive, and run them through a reduction transmission. I'd think that a ratio of 48:1 or a bit higher would be a good mix of speed and torque.
You could do that with off-the-shelf transmissions here:
http://www.andymark.biz/am-0141.html (3 stacker boxes)
Or here:
http://banebots.com/pc/P80K-nnnn-0005/P80K-444-0005
I would run an auto-resetting 40 amp fuse through the banebots transmission. The cim has 103 oz-inches @ 40 amps. That's 0.536 lb/ft of torque, and through the transmission will be 34 ft/lbs. (Someone can check my math if they like). That's a safety factor of 2 against the rating of the banebots gearbox. You could drive the steering with 35 chain from mcmaster, and simply have a foot control that turns the current on and off, left and right.
Unread 22-06-2010, 22:17
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
I completely agree with this. Simple and solid is absolutely better in this situation.
My suggestion would be to install a 2nd steering wheel at foot level, directly attach it via rubber belting (or chain) to the original drive shaft. BAM there you have it!
This allows the cart to still be steered by its original wheel as well.
Now if you want to get extra fancy with it, you could also attach the accelerator to the steering wheel. This will make the steering wheel act as the gas pedal.
(ie. When he pushes in on the steering wheel, it causes the cart to accelerate.)
This would allow him to use both feet for steering, instead of just his right or left and thus, makes it safer. <-just an idea
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 23-06-2010, 01:45
The problem you'd get with a second wheel is the lock-to-lock turning is 3 full turns. Most of the time, you'd only need a little bit of steering, but when making a tight turn, you can easily run into trouble. If that were done, I'd locate it off the drive shaft (structural addition may be needed) and link it 1:1 or maybe 1:1.5, then put a spinning flat knob on the additional wheel, equipped with a bicycle toe clip and most probably a heel jam of some form, to allow the driver to fully turn the wheel. Some buses have a small knob sticking up from the wheel; this would serve a similar function.
theaznevan theaznevan is offline
Chief Executive Officer
AKA: Evan Giarta
FRC #1671 (Buchanan Bird Brains)
theaznevan is an unknown quantity at this point
wow everyone here has got great ideas, and i take no offense if you guys don't like my idea. how about a tank drive kind of system, two pedals, one on the left other on the right and each control its respectable side of the cart. (right controls right side wheels, vice versa). another parking brake kind of pedal can control forward/reverse drive. the problem i see here is this system is highly custom configuration and might cost big bucks. nevertheless its an idea! not very detail im afraid though haha. i wish the best of luck and recovery to you, your son and your family!
Unread 23-06-2010, 02:07
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
I applaud your input as such a new CD member, (welcome to CD by the way) though this is time for a teaching moment. That is a good idea however <lesson>previous posters have already come up with it and nixed it. Reading a thread in it's entirety as well as searching before you post will yeild much better forum usage for all!<\lesson>
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 23-06-2010, 02:58
AKA: Sierra 117
FRC #2395
Great idea! I had thought about using something like the wheel knob (also found on some tractors and semi-trucks). A device like this would help the user greatly!
Also, if my understanding of the lock-to-lock being 3 turns is correct, then couldn't you just make the "foot wheel" a smaller diameter then
the main wheel to decrease the number of rotations it takes to hit its left or right limit?
Unread 23-06-2010, 09:05
i'll look into a "cim" motor as i am not familiar with it. on the other hand we use a bosch wiper motor for trucks & rvs that has 38 # torque and is 100% duty cycle.
Unread 23-06-2010, 23:22
AKA: Alan Wells
FRC #1350 (Rambots)
the Chiaphua Components Ltd. Industrial Motor (CIM):
From Andymark.biz
Performance specifications
Voltage: 12 volt DC
No load RPM: 5,310 (+/- 10%)
Free Current: 2.7 amps
Maximum Power: 337 Watts (at 2655 rpm, 172 oz-in, and 68 amps)
Stall Torque: 2.42 N-m, or 343.4 oz-in
Stall Current: 133 amps
Unread 24-06-2010, 09:26
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
There are many motor choices here: http://www.robotmarketplace.com/prod...tors_main.html
Do you know what steering torque is required to turn the golf cart?
Unread 24-06-2010, 10:31
Natesbug73 Natesbug73 is offline
FRC #3168
Natesbug73 is an unknown quantity at this point
I'm thinking of two ideas:
1) gear welded around the original steering shaft, hidden under the body panels somewhere, driven by a worm gear on a CIM motor. Controlled by 2 buttons, left and right.
2) More complex, remove original transaxle from rear, run tank drive thru two transmissions, power wheels style, remove front steering altogether, install front wheels much like those on zero-turn lawn mowers. Same concept actually, just electrically powered instead of hydraulically.
pic: 1029 cart - Rene de Cart bjimster1 Extra Discussion 6 03-03-2007 20:47
FIRST GOLF Uki General Forum 8 09-04-2005 18:15
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
Golf AdamT Fundraising 4 02-11-2002 23:07
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
