Go to Post ...can I play a computer game during a competition, while i'm suppposed to operate the robot? - Gal Longin [more]
Unread 24-06-2010, 12:13
Chris is me's Avatar
AKA: Pinecone
Re: Drive Train Prototype
Ah. Looks like they've been re-designed. The roller mounting tabs look a lot sturdier. It looks like the rollers still rub against the mounting tabs though. That's a bit disappointing.
I think that's an intended feature of the wheel; you can tighten and loosen the rollers to get varying degrees of forwards versus sideways traction.
Unread 24-06-2010, 12:43
So it's not a bug, it's a feature? :-)
Seriously though, even if you loosen the rollers, they are always end-loaded when the wheel is being driven. This creates substantial friction. Roller bearing friction increases traction in the fwd/rev direction, but decreases traction and force in the strafe direction. For many applications (like Breakaway?) this may be a good trade-off.
I like the look of the new steel end-plates. The mounting tabs look quite a bit more rugged. The aluminum tabs on the 8" AM mecs bend very easily - even to the point of locking up the roller.
Unread 24-06-2010, 13:11
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by GarrettF2395 View Post
Darn it! You guys beat me to it.
I've been playing around with this idea in my head for awhile now, though it's great to see someone actually build it.
Great work, make sure to run some good tests on it and let us know what you find!
That's pretty much what what I was going to say. I had already started CADing this and was trying to think of some other methods to switch it than pneumatic cylinders, but nonetheless I love it, keep up the good work guys.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 24-06-2010, 14:40
I don't understand. Are you stating that as a deficiency of this specific wheel design, or of mecanum wheels in general?
Unread 24-06-2010, 15:20
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Ok question time.
Is there a reason as to why you decided to have the mechanums on the outside instead of the inside?
Did you guys play around with any other configuration ideas, such as having all 8 of the wheels on the ground at once?
While I can't speak for the OP, when I CADed up an idea almost identical to this after Atlanta I put the traction wheels on the inside to allow for easier turning in that configuration.
Unread 24-06-2010, 15:24
AdamHeard's Avatar
Lead Mentor
Originally Posted by 548swimmer View Post
For Overdrive we had a robot with eight wheels that could switch between two sets of four. The chassis sitting in our shop weighs under 40 lbs, though barely.
I'm not sure what you're referring to, but when my team quotes drivetrain weight we talk EVERYTHING; wheels, electronics board, battery mount, chain, bolts, etc...
If you hit 40lbs with that standard, I'm highly impressed.
Unread 24-06-2010, 15:43
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
I must say that I too have been toying around with this idea in my head. impressive work, though. I hope you guys get to use it in next years game
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 24-06-2010, 16:24
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
As far as the 40lb one from the robostangs:
I haven't weighed it myself but heres a picture of it. Imagine changing the larger wheel for a mecanum and mirror those wheels in the front. http://www.chiefdelphi.com/media/photos/27459
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 25-06-2010, 00:00
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
It's about 40 lbs with all the wheels, the old IFI control system, battery MOUNT but no battery, and all the pneumatics.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 25-06-2010, 00:18
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Way to go Nitesh and WBI - this is a cool design! I hope you bring this to IRI so we can check it out.
The bodies of these wheels are actually old and an inferior version of the current version. The plates used on this jump design are from 2008. These tabs were significantly less rugged, since the steel wall thickness was only 0.04" instead of the current thickness of 0.05".
I find that the 8" Mecanum tabs are quite sturdy.
Andy B.
Unread 25-06-2010, 09:59
nitbaj's Avatar
nitbaj nitbaj is offline
AKA: Nitesh Bajaj
nitbaj will become famous soon enough
Originally Posted by Hawiian Cadder
how much does that weigh?
I currently weighs around 90 pounds with everything on it. It's pretty ridiculous, but we didn't really worry about weight when designing it this time around. The frame members are pretty much all 80/20 and we didn't put lightening holes in any of the other plates, so I imagine the weight could drop quite a bit. Weight will probably be one of the next big considerations in this design.
We put the mecanum wheels on the outside because we thought those would be the primary driving wheels, and then the traction wheels would be used in a pushing match or a similar situation. And if a robot with a relatively high center of gravity is moving quickly on mecanum and switching directions, it is much more stable to have the wheels on the outside.
We thought about different things you could do with all 8 wheels on the ground, but it seems like you don't gain a lot with that because you lose both your traction and maneuverability.
Originally Posted by Alan Anderson
Does it spin in place well? It looks like the mecanum wheels might need to be swapped.
We haven't had any problems with the mecanum drive spinning or strafing. I believe our wheels are on in the correct orientation. Unfortunately, we've already made the mistake of putting them in the wrong spot once this year, so we wouldn't want to mess up again .
Thanks for all the compliments, and if you have any other questions or comments, please post them.
Unread 29-06-2010, 03:46
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
The wheels are definitely not in the correct orientation. When viewed from the top the rollers of the 4 wheels should form an X.
Mentor 2415
Unread 29-06-2010, 08:31
Originally Posted by sdcantrell56 View Post
The wheels are definitely not in the correct orientation. When viewed from the top or bottom the rollers of the 4 wheels should form an X.
When viewed from the top they should form an X.
When viewed from the bottom they should form an O.
see this post:
http://www.chiefdelphi.com/forums/sh...4&postcount=18
Unread 29-06-2010, 11:49
Aren Siekmeier's Avatar
on walkabout
Also, tank turning with the traction wheels will be easier with a shorter wheel base because you will get less tread rub.
Unread 01-07-2010, 12:09
Thelilpluck461 Thelilpluck461 is offline
FRC #0461
Thelilpluck461 is a splendid one to beholdThelilpluck461 is a splendid one to beholdThelilpluck461 is a splendid one to beholdThelilpluck461 is a splendid one to beholdThelilpluck461 is a splendid one to beholdThelilpluck461 is a splendid one to behold
There is only one Solenoid on it, and two accumulators. If you look at the start of the video it is mounted just north of the power switch.
Drive Train ryan25 General Forum 28 23-12-2009 21:49
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 01-02-2009 02:11
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
