Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 25-06-2010, 10:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Plaction/Traction coefficient of friction?
I was hoping someone had done traction tests on AM plaction or traction wheels and hoping they would be kind enough to share their results of lateral/longitudinal static/dynamic friction coefficients.
I know this an experiment that teams can do themselves, but suffice it to say that my team is in-between homes right now and we're not able to have regular meetings.
Unread 25-06-2010, 12:05
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: Plaction/Traction coefficient of friction?
Wouldn't the latitudinal and longitudinal values be the same?
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 25-06-2010, 12:17
Joining the 900 Meme Team
FRC #0079
Can you think of any reason they wouldn't be?
Unread 25-06-2010, 12:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Lat/Long traction will be different, I think, for these reasons (and possibly more I haven't thought of):
The tread typically has an asymmetric tread pattern.
Latitudinal tread has an edge exposed that might dig into the carpet.
Longitudinal direction is curved with the wheel, and when pushed in that direction will compress more on the "up-hill" side of the wheel and loose traction in the "down hill" side of the wheel leading to variations in contact pressure which can lead to variations in grip.
I've attached a very quick paint sketch of this, red representing a pushing force and the green lines representing normal force on the wheel, exaggerated for effect.
Name:	wheel traction.PNG
Unread 25-06-2010, 15:02
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
In that case, wouldn't the thickness of the wheel matter as well?
Unread 25-06-2010, 15:35
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Quite possibly, though any information is better than no information. I highly doubt that a 1" wide wheel will be wildly better or worse than a 2" or 3" wide wheel.
Unread 25-06-2010, 15:50
Chris is me's Avatar
AKA: Pinecone
For calculation purposes in a drivetrain, I've been told 1.4 is a safe static CoF for roughtop on carpet in the direction of motion (basically, when gearing for traction limited pushing power / acceleration)
If you need more precision than a good estimate, I would experimentally determine this for yourself.
Re: Coefficient of Friction on Carpet? xdevon.rochelle Technical Discussion 8 10-01-2010 21:07
Coefficient of friction fabalafae Math and Science 4 16-12-2008 22:35
Coefficient of Friction VEN Technical Discussion 10 30-12-2006 18:36
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
Skyway Coefficient of Friction HPA_Robotics_13 Kit & Additional Hardware 1 25-01-2005 06:26
