Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Unread 26-06-2010, 00:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: How did teams think of using the 'reverse curl' to get on the bar?
1. Glad that you mention us.
2. We initially thought we should hang from the vertical bar because it was more versatile then the horizontal bar. We also determined it would be easier on the drivers because it required less precise line-up and they could just ram the robot into the tower to hang.
3. We then looked at ways to implement this, including a four-bar linkage and the reverse curl method. One was the easiest, lightest, smallest, etc. and so we used it. It is powered by a CIM motor, 805:1, through a DeWalt then a Toughbox, plus chain reduction, and requires no bungee.
Kettering Motorsports
How many teams are really using the ir R.C. Sensors 12 19-02-2008 19:17
How early in the season did you get to test your programming? EHaskins Programming 18 20-02-2007 00:22
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
