Go to Post Why, yes. I do use Windows, why do you ask? - dtengineering [more]
Unread 28-06-2010, 09:16
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: How did teams think of using the 'reverse curl' to get on the bar?
Here is a great thread on the "reverse curl" without really saying so much:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80425
Unread 28-06-2010, 22:07
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Originally Posted by Chris Fultz View Post
I think a key came with how you interpreted and defined the problem -
If you interprete "hang" - then you focused on grabbing the top and pulling yourself up.
If you interpreted "get the robot higher than the platform" - then that opened up a lot of different ideas.
We didn't start working on this feature until the last week of the build season. As others have said, we weren't sure it was worth it for just two points. Our base robot was pretty heavy (a very rugged frame) so we didn't have much weight to allocate to the hanging mechanism. We considered grabbing one or two vertical poles and flipping up but didn't think we could get the mechanism working in just a couple of days. The hanger we ended up with was pretty reliable, very lightweight and very easy to develop. We designed it to work on the side bumps for two reasons: we decided fewer robots would attempt to hang from the side and the distance we had to lift was much less. Our mechanism was not as fast as others but was still pretty fair. In one match, our driver was defending in the far zone, scored, crossed the far bump, climbed onto the near bump, moved into position and hung - all in the last 13 seconds. Not too bad for a very simple mechanism. The design had nothing to do with how the problem was interpreted - the design was the result of practical considerations.
Unread 29-06-2010, 09:31
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
For 1511, the concept had come up in the original brainstorming, but was not initially selected. After watching teams compete at our first regional and struggling to get a consistent hang with our designed mechanism, we scrapped the first design and spent the next week on the reverse curl retrofit.
At our second regional Thunderfoot underwent a dramatic transformation on Thursday. I'd say that we relied heavily on the success of other teams' reverse curl engineering!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
How many teams are really using the ir R.C. Sensors 12 19-02-2008 19:17
How early in the season did you get to test your programming? EHaskins Programming 18 20-02-2007 00:22
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
