Go to Post I love first because of the late nights, the unparralleled stress, the excitement, the emotion. Because of the close defeats, the close victories. Because of the pride, the sense of accomplishment, the feeling of embettering the world. But most of all, because of you, the other teams. - Keith Chester [more]
Unread 28-06-2010, 16:24
MWB's Avatar
MWB MWB is offline
Building and building.
AKA: Marcus W. Byrd
FRC #3716 (WABots)
MWB is just really niceMWB is just really niceMWB is just really niceMWB is just really nice
Send a message via AIM to MWB
Re: pic: 2011 Drive Prototype
Originally Posted by CraigHickman View Post
Looks like a nice design. A prototype is a functioning physical mockup or first run mechanism. For reference:
I quite like your modeling work, keep practicing! My suggestions for the design:
-You probably don't need the superstructure.
-Have you taken into account materials? Depending on what thicknesses and alloys you're planning on using, you might be able to save some weight here and there.
-How thick is your belly pan? It seems rather thick. You should be able to go pretty thin, ie .090 or .040 while still maintaining plenty of strength if you're securing it in place correctly.
-"Secret CAM system", huh? Now I'm curious!
Thanks for the the info! Well the upper-structure is 1/16in. The belly pan could be lighter, but right now it only weighs about 2lbs so if less weight is needed i will change it.
The secret CAM system does not necessarily lie in the blocks or the actual cam, it lies within the method in which the CAMS are turned... Think about it
Marcus W. Byrd
Team 3716
Lead CAD/Design and Fabrication.
2992 with 5 motor 2011 Prototype Drive System 45Auto General Forum 4 22-04-2010 23:01
pic: 2826 Halonomic Drive Prototype Tyler Olds Extra Discussion 15 10-12-2009 22:38
pic: 1010 Drive system prototype joeweber Extra Discussion 10 24-08-2009 15:28
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 01-02-2009 02:11
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
