Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
Unread 27-06-2010, 22:07
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Any good summer electrical projects?
I was just wondering if anyone had any good electrical projects that I (or anyone else interested) could do now that school's out for the summer. I'm currently looking to get parts to build a Mintyboost, but after that I'm not sure what I should play with. I'd really like to get my hands dirty now that I've got some free time. if it helps at all, I already have a basic knowledge of electrical circuits, though I'm a little fuzzy fuzzy on capacitors and haven't gotten into logic gates, and I know how to solder and all that good stuff. I just haven't been able to find any projects here on CD while I was digging around.
so to all you more experienced electrical types, what kind of electrical projects or learning resources can you recommend to a high school student like myself?
Unread 27-06-2010, 22:24
BX MARK's Avatar
BX MARK BX MARK is offline
AKA: Mark
FRC #3542 (S.P.E.E.D.)
BX MARK will become famous soon enoughBX MARK will become famous soon enough
Re: Any good summer electrical projects?
The electronics guy on our team took home our Robot cart and is wiring it with lots of cool lights over the summer.
2011-2012 Team 3542 S.P.E.E.D.
2010/2011Bedford Express Captain
Unread 27-06-2010, 22:33
ATannahill ATannahill is online now
AKA: Alex Tannahill
I suspect that Chris is more into the circuit design aspect of EE. Am I right? This is not often discussed in FIRST.
Chris you should look into some of the more common logic gates and learn what they do. After you do that, try to make a timer or stop watch. I don't know of any activity kits that would help you.
- Arizona North
Unread 27-06-2010, 22:41
AKA: Chris Sherwood
absolutely right, alex. I'd try doing something with an arduino, but I'm still trying to figure out how all this works, so I'd rather not get in too deep. I will look into the stop watch idea, though. messing with the logic gates is probably a good place to start
Unread 27-06-2010, 22:50
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
my summer project is making a Lego breakout for an arduino. this way i can make lego robots and then use the much more powerful arduino to control them.
Unread 27-06-2010, 22:54
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Zholl,
If you like to control stuff with a computer there is a kit made by Velleman-kit that is cool. It is model # K8055. You will need to solder it together and then you have a USB interface device that has lots of inputs and outputs and even has two PWM outputs that could control a Victor or Jaguar. Sample code is supplied in VB, C++ and a few others. I used it in an EECT class I taught last semester for a basic overview for students to learn about PC control.
It is great to hear you want to do something this summer. That is way better that setting around playing video games. Good luck with what ever you decide to tackle.
Hugh
Unread 27-06-2010, 22:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
hmmmm....I just got done putting together a computer, which involved some welding, as well as assembling an electronic kit (the clock).
http://www.selectric.org/ibmpc/atxpc.html
Several years ago I built a "homebrew" Nixie clock, but I have sources for old parts, which you may not have available.
http://www.selectric.org/nixie/index.html (scroll down to the bottom of the page).
You might not want to get into this high voltage stuff until you understand the necessary safety precautions.
When I was young, we had Heathkits available, although we never had enough money to buy them ourselves. Dad bought a TV kit that my brothers and I put together when we were in Jr. High, I still have the TV, it still works.
My guess is that getting into electronics now, is not the same as it used to be....everything now is so small! All the ICs are surface mount, etc. And vacuum tubes are pretty much gone, even as displays.
Unread 27-06-2010, 23:21
Best Available Data
FRC #1778 (Chill Out!)
In my experience, Ardunios are pretty hard to mess up. The materials aren't written for engineers and technical people, they are written for non-technical people who want to get their feet wet. It certainly helps to have people you can ask, but I'm pretty confident you could figure an Arduino out on your own. In addition, their forums are conveniently filled with knowledgeable people who love to help.
You might try this for some old time electical fun. Some of the projects would make neat shelf displays or gifts.
Unread 28-06-2010, 03:14
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We are trying to build something that we can use for next year. One of the project ideas is a battery load tester that will check if the battery is still good. Our design can be found at http://proj.titanrobotics.net/docs/Robot/BattTester
Unread 30-06-2010, 01:17
AKA: Chris Sherwood
That's really cool! I'd love to do something like that, but I don't think I have a good way of getting any nixie tubes...
anyway, I think I've got a decent idea of what I'll be doing this summer, and I also found my dad's old EE texts, so I should be good for the next couple months. I would like to know if there's a particular model of Arduino I should get if I should go in that direction, or if it's really more of a "what fits my budget" kind of deal. either way, I'm making a parts run tomorrow
Unread 30-06-2010, 01:57
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
I am interested in what you have done but for some reason I cannot get to the web pages. Is there any reason for this? I have tried on 2 of my computers with 2 different web browsers. I also tried at different days/times.
Unread 30-06-2010, 03:23
MrForbes's Avatar
AKA: Jim
Oh, my hosting company seems to have some DNS issues....sorry!
You might try it from a different internet provider, perhaps at some place that has free wifi.
Unread 30-06-2010, 09:00
Back after 4 years off
FRC #5279
Asking for good electrical projects is going to yield you tons of different opinions. Let us know what you might be interested in (basic home automation, Remote control vehicles, electronic art, hobby radio?) and we can give you some basic projects to get you feet wet, and then send you in the right direction to find increasingly complex projects. For example if you want to stay in the robotics field, perhaps start with beam robotics, then move on to incorporating an arduino (or your choice of other micro) and using servos that can be controlled directly with the board. Eventually build your own speed controllers, then try different sensors. If robotics doesn't seem practical to you or their is something you find very interesting let us know and we can give you better ideas of what may be fun.
As far as building the classic circuits (stop watch, head phone amp, etc) I appreciate what they are and that they teach basics of electronics but I don't think it is necessary to start this low level. Eventually you learn how/why these things work, I believe that you can start out working at a higher level, if you need an amp you can buy an IC that will serve your purpose, eventually you will learn what is going on inside, in the mean time it really isn't that important. See the big picture first, the rest will make sense as you go.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 30-06-2010, 17:09
AKA: Chris Sherwood
Thanks for the advice. As far as what I'd like to do, though, I'm not really sure. I'm starting with this Mintyboost project simply because it's simple and highly practical. Otherwise I know I just want to mess with something. I'm sure I'll get a better idea of what I'm really interested in once I've done a couple projects, but this is all pretty new to me
Unread 07-07-2010, 07:50
mikets,
I would like to remind your team that the AGM batteries we use are slightly different than a typical lead acid cell and may yield some misleading results. Double check the battery spec sheets from the manufacturer.
Chris
Summer would be a great time to get your Ham license. There are a variety of small kits for ham transmitters and simple receivers. Check out Ramsey kits or just search the internet. Ham clubs have classes and hamfests (ham flea markets) run license tests and are a great source of cheap parts and used equipment. The Colorado QRP club (that is for low power users) has a website and list local fests here http://www.cqc.org/swapm.htm
2009 Summer Projects boehmz 3D Animation and Competition 12 10-07-2009 02:04
Summer VEX Projects? Donut VEX 17 30-06-2007 01:53
Any students good with flash willing to undertake few simple projects for offseason? Ken Leung General Forum 1 16-10-2006 11:34
CMUcam summer projects Andrew Schuetze Control System 5 01-06-2005 09:29
summer projects oreocookeee Chit-Chat 1 05-07-2002 23:17
