Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
Unread 29-06-2010, 22:29
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Dewalt drive question
In the dewalt plans for the CIM adaptation there is a plastic piece that attaches to the top hat gear. It says it is .188 thick but I don't see from the plans why it needs to be that thickness. Looks to me that it could be .25 with no problem as long as the relief is cut around the edge to allow for engagement of the planet gears. Am I looking at this correctly?
Thanks
Bruce
Unread 30-06-2010, 07:12
Re: Dewalt drive question
Can you provide a link to the plans you are referring to ?
Unread 30-06-2010, 07:34
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
This is the white-paper:
http://www.chiefdelphi.com/media/papers/1592
I don't know why you would need to "cut a relief" (what do you mean by this?) but it does look like the plate could be 1/4" thick without any detriment.
Unread 30-06-2010, 09:56
Bruceb's Avatar
The relief I am talking about is seen on this picture.
See attachment.
Bruce
Unread 30-06-2010, 10:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Ah, I see, that would probably be important
Unread 30-06-2010, 10:16
REVving up for a new season
FRC #2848 (All-sparks)
The thickness of the plate is a factor of making the sun gear interface correctly into the transmission AND the mounting of the CIM motor. If that plate were to be .25 instead of the .188 the press distance on the CIM would have to be adjusted and would most likely cause interference with the end of the CIM output shaft hitting the second stage in the planetary.
If you have the ability to cut a relief why can't you just make the plate to the proper thickness?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 30-06-2010, 17:18
Bruceb's Avatar
Greg, thanks for the info. Not saying I can't make it that thick. I just didn't want to if I didn't have to. So ...what exactly does it do? I thought it just held the planet gears in.
Thanks
Bruce
Unread 30-06-2010, 17:42
Thanks
Bruce
the sun/carrier gear that is used as the pinion gear for the CIM motor attaches via small pan head screws to the plastic plate in question. It acts as a spacer plate and a bearing to ensure that the gear is properly set in the transmission and rubbing on the CIM mounting plate is not a big deal.
Dewalt Question sdcantrell56 Technical Discussion 0 29-04-2008 23:20
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: DeWalt drive base: side module dbell Extra Discussion 22 09-07-2007 19:11
Warning: 1213's DeWalt 1/2" keyed final drive Jack Jones Technical Discussion 1 04-02-2007 17:18
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
