Go to Post This reminds me a lot of how millennials are regularly called out for simply being younger and having different perspectives. In the end it's the ones who are calling them out in unprofessional in ways that end up embarrassing themselves and looking uninformed. - Karthik [more]
Unread 01-07-2010, 14:02
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
Team Role: CAD
kinghashbrown is an unknown quantity at this point
pic: 6 wheel drive train concept picture one
Unread 01-07-2010, 14:14
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: pic: 6 wheel drive train concept picture one
Looks like a nice concept. I like it.
A few questions though. The Gearboxes appear to be floating in space, do you have a planned attachment method yet?
I'm not personally a fan of running the chain over 8020 cross bar on plastic. I've seen it done before, and it works, but my team had issues in 2008 where we broke through some plastic this way. Make sure you get a strong delrin to rest on the 8020 bars.
How do you intend to tension the chains with the plastic blocks? If you slide them, you'll shorten the chain on one end, and lengthen it by the same amount on the other side, and it won't tension.
I like the use of 8020 for a test bed, nice and versatile and easy to work with.
If your unsure of using e-clips or cotter pins, definitely use e-clips. Cotter pins are relatively bulky (for this purpose) and believe it or not they're harder to remove than e-clips. Cotter pins are also a pain if the bend because they stick out. e-clips are a lot cleaner.
Unread 01-07-2010, 14:27
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
I'd go with snap rings, which are much stronger than e-clips.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 01-07-2010, 14:53
Chris is me's Avatar
AKA: Pinecone
Snap rings are the best! They weigh nothing and are easy and quick to install.
I've seen Delrin, HDPE, and nylon guides successfully used in this application before.
Unread 01-07-2010, 15:10
ttldomination's Avatar
Sunny
I too am interesed about your gearbox attachment methods.
1648: 2013-2014
5283: 2015
Unread 01-07-2010, 16:10
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Originally Posted by kinghashbrown View Post
My intent is to tension the chains by spacing the white plastic off the 80/20 cross bars. I would like some feed back on that idea.
We have used what are effectively plastic blocks to tension our drive chains for the past four years without any issues. We usually use oil impregnated nylon, turned on a lathe so that it has a lip sticking up where the chain will ride over it. This way the chain rollers are supported rather than the connecting plates.
This method of tensioning can be seen clearly on our 2008 robot, here. In that photo you can also see the use of UHMW Polyethylene chain guides, purchased from McMaster.
I think it's worth noting that I was a little skeptical of plastic tensioners and guides at first, but after seeing our 2008 robot run around with its ridiculous serpentine wrapping of the chain and no noticeable drag in the drivetrain, all of my worries vanished.
Unread 01-07-2010, 22:28
AKA: Joey Fisher
Team Role: CAD
I plan on replacing the front face of the gearbox with a plate that has all the holes and extends off and inch and a half to the left and right of the box. Four aluminum spacers will run from the plate to the 80/20, 1/4"-20 bolts will go through them and screw into t nuts in the 80/20 t slot profile. However I am somewhat concerned that if someone hits the center wheel it could cause the SS to move out of place. I haven't really worked much with 80/20 before, so I don't know if that is a legitimate concern.
p.s. Picture two will have this in it. It should be up tonight, right after my laptop is done making it.
Unread 01-07-2010, 22:41
AKA: Joey Fisher
Team Role: CAD
Thanks for the info. I found it helpful.
pic: Simple Drive Train Concept JesseK Extra Discussion 5 09-01-2010 22:28
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 16-04-2007 14:22
pic: One Omni wheel drive done falconmaster Extra Discussion 2 11-01-2007 19:26
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
