Re: pic: 2011 Drive Prototype
- Cam actuated tensioners? Check. - Self locking style cams? Check. - 2x1 frame members surrounding semi-elliptical bearing blocks? Check. - External cantilevered wheels? Check. - Center wheel direct driven? Check. - Two speed custom gearbox? Check. - Belly pan for electronics, cut on a waterjet/laser? Check. - Welded sheet battery box? Check. I could keep going on. Are you SURE it's not a copy of the 254/968 system? |
Alright, I would personally view it (and it appears several others do as well) as the same design. I accept that you think of it as a different design though.
Grandfather's axe is handed down from generation to generation. Every now and again, the head or the handle is replaced due to normal wear and tear of use, with a slightly differently shaped head or handle. At what point does it stop being Grandfather's axe?
Spoiler for The Answer to the Question:
I'm not going to say that you didn't get inspiration from 254. I don't think anyone ever did say that. What got people annoyed was that you made mostly cosmetic changes, and then appeared to claim that because you made some small changes, it was your design, not 254's. Again, this is simply the impression I got. See the Grandfather's axe answer area above--I think we're on two different answers here. BTW, 330 has yet to use a WCD design. 6WD? Yes. Shifting? Yes. Direct drive to the center wheel? I can't say I remember one--possibly in 2009, which wasn't a WCD design any way you look at it. Cantilevered? Nope, I can't think of a single 330 robot using a cantilevered wheel. Battery box? A couple of times, but I don't remember materials, etc. Belly pan? Well, we do use a plywood base for strength and mounting stuff... But no tensioners of the cam style, let alone embedded in the frame rails. Elements, we've used. Design, we haven't. |
#7
That would be a 233 design cue. Far too many people see our robots from the last 2 years and think it's our idea. Just one of the many we've borrowed from other great teams over the years.
#8
Don't you even use 233's Water jet? So technically you're borrowing their machines too!
#9
That's correct. 233 has waterjetted numerous parts for us the last two years and we help them out by making things for them whenever possible.
#10
Like wheels for their practice bot... right?
#11
We manufactured a number of drivetrain components for them this year.
#12
Why was that? Was it because you used similar components and you already had the g-code written. So it was faster and more efficient to do them all at once?
#13
For a number of reasons. We had wanted to do some sort of collaboration with them on a summer project for years but had never been organized enough to make it happen. We both were going to make similar drivetrains and we were already making about 8 sets of everything so it didn't make it any more difficult for us to make 10 of the components common to both teams.
#14
and cause 233 is just plain lazy
#15
To all of you pontificating that Marcus copied the design of 254 & 968, I ask who cares? We have a student using Inventor to design a drive base instead of wasting his time playing video games. I see nothing wrong with that.
I find all the recent berating replies to student designed components counter-productive. Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? Spend some time giving constructive feedback instead. |
| 2992 with 5 motor 2011 Prototype Drive System | 45Auto | General Forum | 4 | 22-04-2010 23:01 |
| pic: 2826 Halonomic Drive Prototype | Tyler Olds | Extra Discussion | 15 | 10-12-2009 22:38 |
| pic: 1010 Drive system prototype | joeweber | Extra Discussion | 10 | 24-08-2009 15:28 |
| pic: 1885's Drive Train Prototype | JesseK | Extra Discussion | 5 | 01-02-2009 02:11 |
| pic: 213 - Drive prototype teaser | Tyler M. | Robot Showcase | 10 | 07-01-2007 20:56 |
