Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Unread 07-07-2010, 08:08
Re: pic: Off-Season Kicker Design
Originally Posted by apalrd View Post
I would actually recommend a pot over an encoder because it's position is absolute instead of relative.
Not all encoders are relative. There's an absolute encoder in the 2010 KoP:
http://www.austriamicrosystems.com/e...5030-Downloads
The key is to isolate the pot from the shaft.
Why is that the key? Did you try it both ways and it failed when directly connected and worked when chain-driven?
Unread 07-07-2010, 09:10
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The key to not damaging the pot.
We anticipated that the stresses on the shaft would break a potentiometer if it was connected directly to the shaft. We isolated it with a chain so that the rotary motion was transferred, but any other forces were not. We used a standard 270-degree pot.
Although a magnetic encoder would remove any mechanical connection between the sensor and the shaft, so that might be a better solution then a potentiometer.
Kettering Motorsports
Unread 07-07-2010, 09:50
Isolating the pot from the shaft (via a chain or belt etc) is certainly a solution, but not the only way.
If you use the pot to replace one of the shaft bearings then of course that's going to put unacceptable loads on the pot. But if you mount the sensor directly to the shaft (through a simple coupling) on the outboard side of one of the end bearings it will not bear the shaft loads.
Unread 07-07-2010, 12:17
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Essentially what we did. We had a gear on the end of the winch shaft. That gear drove an idler shaft that had the pot attached to the end of it. The pot (and the encoder that replaced it) were not bearing any loading from the kicker.
Unread 07-07-2010, 12:48
Sure, that's a good solution. But the point was it's also possible to mount the pot (or encoder) directly to the shaft through a simple in-line coupler on the end of the shaft. With that approach there would be no undue loads on the pot. It's not the direct connection to the shaft per se that causes the loading problem, it's if you try to use the pot in place of a load bearing.
Unread 08-07-2010, 00:42
In-line connection, 330 style: make the shaft extra-long by an inch or so, and turn that inch or so down to about the same diameter as the pot shaft. Put the ends of the shafts together in line, then put surgical tubing around the small portion and ziptie it down solidly. That way, even if something goes really wrong, the pot (or encoder) isn't going to be too banged up (it has its own mounting point off the axle).
Unread 08-07-2010, 08:03
Jared Russell's Avatar
Taking a year (mostly) off
Our team used a US Digital MA3 absolute magnetic encoder directly coupled to a small bore in the end of our kicker shaft and it held up great. We used the sleeve bushing model, rated up to 10,000 rad/secē acceleration and 100 RPM continuous top speed, but you can get the ball bearing model (250,000 rad/secē; 15,000 RPM) if you want even more of a safety margin. No detents or hard stops, no gap in sensing, and no wiper wear over time - I would heartily recommend using them in this application (or wherever a pot would be appropriate).
Link: http://www.usdigital.com/products/en...ary/shaft/ma3/
Unread 08-07-2010, 19:23
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Team 691 has done the same thing for awhile. We however create a flat on the end of the shaft so that the surgical tubing holds on better. We used this to attach encoders to a ~900 RPM shaft and had no issues.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
pic: 1503's Off-Season Project Pat Fairbank Extra Discussion 28 31-12-2008 14:27
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
Help design off-season project efoote868 Chit-Chat 4 09-04-2007 09:19
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Gearbox Matt Reiland Robot Showcase 5 01-02-2005 20:53
