Go to Post The minute you get a functioning mechanism start working on a better one - [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 07-06-2010, 11:12 PM
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
CAN reliability
One of the things I like about CAN is that it gives us the ability to detect failures (loss of power, loss of communication, etc).
I made a program to do just that, and log it to a file. After running it for an hour, I got some interesting results. I've linked the code and the log file, so I'll explain the format it is logged in.
First off, the file is created in the top directory, using the name "CAN_status_"+timestamp (In the file I've provided, it is 5:33pm on July 6th.)
Anyways, for each entry (each line), there is the status, the list of devices which the status applies, and the timestamp.
The possible statuses are:
  • lost (communication with this Jaguar has been lost)
  • power up (power has been cycled since this was last checked)
  • got comms (communication with Jaguar has resumed, but the interruption was not due to loss of power)
  • brown out (voltage fault)
  • over temp (temperature fault)
  • over current (current fault)
I was surprised at the number of interruptions there were, seeing as the robot was undisturbed during this hour. It seems each of the black jaguars (devices 10, 11, and 12) had an interruption in communication about once a minute, and the tan jag (device 13) had no interruptions whatsoever.
The interruptions seem to be on the scale of 200ms.
Why might there be communication interruptions on an undisturbed robot? Is enumeration a flaky thing?
-- Marshal Horn
Unread 07-10-2010, 11:12 AM
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: CAN reliability
My team used CAN this year on our robot and found some issues with connection. We found that when polling for information while sending output information to fast the jaguars would lose connection briefly. The bandwidth afforded by a serial connection is a lot less than that of a CAN connection. This creates a big chokepoint on sending and receiving information from the jaguars.
Unread 07-10-2010, 12:14 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: CAN reliability
I haven't seen the kind of information in your program, but I've found that CAN is VERY unreliable if there are any problems on your robot that affect the code (primarily its execution speed), the jags will become intermittent (watchdogs I think)
When you were running this, was the robot disabled? If so, is there any change when enabled and you can see if the status LEDs blink?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 07-10-2010, 02:11 PM
Re: CAN reliability
RS232 and CAN are both serial connections. But their speeds may differ.
Does anyone know the max speed supported for RS232 by the various drivers provided (LabVIEW, Java, C++), and do these drivers offer interrupt-driven receive and transmit buffers?
If 115Kbps and interrupt-driven software buffers are supported by the RS232 drivers, it seems that should be adequate for both commands and data acquisition at 50Hz for 5 motors (depending on how efficiently the data is encoded).
Unread 07-10-2010, 04:57 PM
Bot190's Avatar
Re: CAN reliability
By serial, i was refering to the connection on the Crio, The CAN bus has a bandwidth of 1Mb/s much greater than that of the serial connection on the Crio.
Unread 07-11-2010, 03:52 AM
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: CAN reliability
Marshal - You mention the black jags, so were you using the serial connection as well? (I should say I haven't actually looked at your code)
Does anyone have a 2CAN that they try could the code with? I've been thinking about switching to CAN this year, but if it's going to be flaky, I'm starting to wonder if that's the best idea.
--Ryan
FRC 766, 2015-, Mentor
Unread 07-11-2010, 07:26 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: CAN reliability
Okay, let me clear some things up:
I had no driver station connected when this code was run. (I was just testing static connectivity, without dealing with the enabled/disabled stuff. This is to help isolate the components of the control system)
The serial port on the cRIO is capable of 14 KB/s (cRIO-FRC operating instructions, found under c:/program files/National Instruments/NI RIO/manuals/crio-frc_operating_instructions.pdf)
The CAN transceivers on the Jaguars are capable of 1 MB/s (page 7 of http://www.luminarymicro.com/index.p...e&Itemid=59 1) It should also be noted that the physical limit for the CAN network when using a Black Jaguar as a master is only 16 devices.
EDIT:
Sorry for the confusion, I had several facts wrong. 14 kb/s is the minimum speed of the CAN transceivers in the jaguars.
Thank you Ether for catching my mistakes.
-- Marshal Horn
Unread 07-11-2010, 09:41 PM
AKA: Ian Thompson
Re: CAN reliability
Could you provide screenshots of your VIs? I'd be interested in writing a C++ equivalent to compare with when I get my hands on the programming laptop and the robot at the same time (I don't have a copy of LabVIEW at home)
Unread 07-11-2010, 11:01 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: CAN reliability
Here's the screenshots. My first post has the basic concept.
I'm using a queue to ensure that the logging process does not slow down the main loop.
The semaphore is opened at the beginning because it is used in the CAN Jaguar VIs to prevent conflicts on the RS232 bus.
This is just a method of filtering out the elements from the array. Only device numbers corresponding to TRUE elements in the boolean array are extracted.
Here's where the message is added to the queue. Where I interleave the numbers with the commas, I should change to "array to spreadsheet string".
If the array of device numbers is empty, nothing is added to the queue.
Here's the actual logging VI. I use the "preview element" function to force the VI to wait until there is an element in the queue, and then it flushes it into an array. The "write to text file" function automatically puts a line return after each element in the array. The reason it opens and closes the file every time is this ensures the write is actually saved to file at that time. (The cRIO caches the writes into large sections, on the scale of 8 or 16KB)
-- Marshal Horn
Unread 07-12-2010, 11:55 AM
Re: CAN reliability
cRIO RS232 hardware can do 115200 baud.
That's approximately 11,520 data bytes per second.
At 50Hz, that's 230 bytes every 20ms iteration (230 bytes each direction, xmit & recv).
Are you trying to send or receive more than 230 bytes each iteration?
Unread 07-12-2010, 02:02 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: CAN reliability
Let's use the voltage mode "set vbus" command, and assume there message sent over RS232 is the very same message sent over CAN.
The sections are:
Start of Frame (1 bit)
Arbitration field (32 bits)
Control field (6 bits)
Data field (vbus is a 8.8 signed fixed-point number, so that's 16 bits)
Cyclic Redundancy Check field (15 bits)
Acknowledge field (2 bits)
End of Frame (7 bits)
That is 79 bits, or 10 bytes. 230 / 10 is 23. At least for the black Jaguar controlled network, the physical limit for devices is 16. (I don't know the physical limit for 2CAN)
Therefore, at least during normal use, the RS232 communication will have enough throughput. Now, during startup, it may take a little longer. I'll get theoretical stats for how long it should take to initialize a Jaguar for position control in just a bit. (Position control is something that takes a lot of initialization.)
EDIT: I was assuming the time it takes for the message to be sent on the 1Mb/s CAN bus is negligible, but I suppose it could be included. 100 bits / 1Mb/s is about 0.1 ms. (The reason for multiplying it by 10, not 8, is to approximately account for the bit stuffing.) Let's make that 0.2ms to allow for a reply message. 0.0002s * 115,200 bits/s means there's about 23 bits of wait time. I'll round that up to three bytes. So it's 230 / 13, which is a little under 18. If you're using speed mode, that would now be 15 bytes. 230 / 15 is a little over 15, and you're almost at the limit there of 16 devices per network.
Now, I've been assuming worst-case scenario: that the entire CAN message is sent over RS232. It's quite possible that only the arbitration and data fields are being sent. The arbitration field is 4 bytes. For "set vbus", the data field is 2 bytes. Add in the 3 bytes of wait time, and you have 5 bytes. 230 / 5 is 46.
It would then be a 7-byte message for set speed. 230 / 7 is about 33.
NOTE: I am following the Robert Bosch CAN standard. The poster I'm looking at is the vector "CAN Protocol Reference Chart" which you can order (free, I think) from can-solutions.com
-- Marshal Horn
Unread 07-12-2010, 02:57 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: CAN reliability
Okay, so on to initialization. Here's a list of commands that would be logical to use when configuring a Jaguar for position control. (I'm choosing position control because it has the most things to configure)
  1. Firmware version (0 bytes data)
  2. Position Mode Enable (0 bytes data)
  3. Position reference (0 bytes data)
  4. Proportional Constant (4 bytes data)
  5. Integral Constant (4 bytes data)
  6. Derivative Constant (4 bytes data)
  7. Encoder lines or Potentiometer turns (4 bytes data)
  8. Break/Coast (1 byte data)
  9. Soft limit switches (1 byte data)
  10. Forward soft limit (5 bytes data)
  11. Reverse soft limit (5 bytes data)
  12. Position Set (4 bytes data)
The sum of data bytes being sent here is 32 bytes, though it is being sent over 12 messages.
If the whole CAN message is sent through RS232, that should be (14*(8+3)+32)bytes / 11,520 bytes/s or 16ms to initialize a Jaguar for position mode.
If only the arbitration field and the data is sent, it should be (14*(4+3)+32)bytes / 11,520 bytes/s or 9ms to initialize a Jaguar for position mode.
So, now that I have some theoretical calculations to compare it to, I shall make some tests.
-- Marshal Horn
Unread 07-12-2010, 02:59 PM
Bot190's Avatar
Re: CAN reliability
Looking at the Can Jaguar library for C++, The maximum size of a sent message is 10 bytes, as was previously determined, and the maximum size of a received message is 14 bytes.
This assumes that a separate message is sent for every request to every jaguar. In this experiment 5 jaguars were used, this would limit the requests for information to 4, but limits the data being received to 3 messages.
Please correct me if I'm not thinking about this right, or if anything looks off.
Unread 07-12-2010, 03:41 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Re: CAN reliability
It seems I don't quite understand their thinking. The maximum length of the data field in CAN is 8 bytes, so the maximum length should be 12 bytes. (I suppose it's true the Jaguars don't have any messages with data fields longer than 5 bytes)
Perhaps there is some error handling in the message returned, which would be added on by the main Black Jaguar?
You are correct that a separate message is sent to each jaguar, in most situations. There are some messages (heartbeat and enumerate) that are sent to all devices. I'm pretty sure that the main Black Jaguar acts both as the master and a slave on the CAN bus.
I don't understand where your numbers (4 and 3) came from. Could you please elaborate?
-- Marshal Horn
Unread 07-12-2010, 04:03 PM
Bot190's Avatar
Re: CAN reliability
If every data request is 10 bytes, and your requesting it from 5 jaguars, 10 bytes * 5 jaguars = 50 bytes, 230 bytes / 50 bytes = 4.6, rounded down to 4 messages.
Given 14 bytes per response for 5 jaguars, 14 bytes * 5 jaguars = 70 bytes, 230 bytes / 70 bytes = 3.3 rounded down to 3 messages. The size of the Messages was based off the C++ Jaguar library, in the JaguarCANDriver.h file if you want to look.
Supershifter Encoder Reliability Problems? Qbranch General Forum 5 02-04-2008 12:55 PM
2007 Radio link reliability problem Dave K. Control System 12 02-02-2007 10:26 PM
Mechanical Reliability Andrew Blair Technical Discussion 20 10-26-2005 09:29 PM
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 08-23-2005 12:25 AM
team 67 reliability? mattshuert OCCRA 6 12-02-2002 03:53 PM
