Go to Post I think candids are my best... I'm sneaky with my 12X optical zoom. - MissInformation [more]
Unread 12-07-2010, 06:23
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: paper: Kitbot Bending Analysis
Originally Posted by Taylor View Post
We are continuing to struggle with the same chain issues. We thought we had traumatized the frame by our elevating technique; unfortunately it appears that simply driving the robot creates stress. This will be great strategic knowledge to implement at IRI.
I'm curious - what types of wheels did you use? We have slicks in front and stickies in back; I'm convinced the extra grip in the stickies can exaggerate the frame bending. Do you feel the same way?
We only used kit wheels during this process, but they were rotated rear to front and back during the process. The problem always followed the sticky wheels. Presumably this is due to the higher coefficient of friction causing more tension to develop in that chain. Good luck at IRI.
Mark
Brick walls are for other people. - Randy Pausch
Bending Metal Jeremiah Johnson FIRST Tech Challenge 2 01-05-2006 01:15
White Paper Discuss: Physics Analysis of a Ball Launcher coastertux Extra Discussion 0 01-02-2006 17:58
White Paper Discuss: Analysis of Ball Drag from Fundamental Physics coastertux Extra Discussion 0 01-02-2006 16:49
bending parts foobert FIRST Tech Challenge 4 15-01-2006 13:17
White Paper Discuss: Team 670 - Universal Drive Systems: Design and Analysis ChrisCook Extra Discussion 13 01-07-2005 23:41
