Go to Post i swear, if it were april fools day, i would not believe this whole lord dumpling/dean kamen thing...but then again, this is FIRST - sure_smile [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 16-12-2009, 02:40
C3PO C3PO is offline
C3PO has a spectacular aura aboutC3PO has a spectacular aura about
ProE on Windows7
Does anyone know how to get the FIRST version of ProE to run on 64 bit Windows7?
Unread 16-12-2009, 11:34
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Re: ProE on Windows7
Hi. PTC will not officially support Pro/ENGINEER Wildfire 4.0 Schools Edition on Windows 7. We are currently working on Pro/ENGINEER Wildfire 5.0 Schools Edition that will support Windows 7, but unfortunately it will not be available until March 2010.
Unread 18-12-2009, 14:33
Thank you so much. I'll try doing the models in either AutoCAD or SolidWorks and then export.
Unread 06-07-2010, 11:22
skotmorris's Avatar
PTC is now offering Pro/ENGINEER Wildfire 5.0 Schools Edition in both 32bit and 64bit for XP, Vista and Win7. Please check out www.ptc.com/go/softwareforfirst to download the installer of your choice.
Unread 12-07-2010, 20:05
jhouser's Avatar
jhouser jhouser is offline
MCAD $@#$@#$@#$@#$@#., Pelco
FRC #1671 (Team 1671)
jhouser will become famous soon enough
Hi Skot,
any reason that it's not yet available in the Windchill software download yet?
Josh Houser
Mentor, Team 1671
MCAD Tools Administrator, Pelco
Clovis, CA
Unread 31-12-2010, 18:03
bcharbonneau bcharbonneau is offline
None #1296 (Full Metal Jackets)
bcharbonneau is an unknown quantity at this point
When I try installing pro-engineer on my Windows 7 64 bit machine it freezes up at 2% of the installation process. Any help would be appreciated.
Unread 31-12-2010, 20:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It's a problem with their "online" installer. It's outright broken, and doesn't work. No fault of yours. You need to use the full DVD installation package.
Unread 02-01-2011, 12:27
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Once you do get it installed though, it does run and is fully supported on Windows 7 x86-64 (Wildfire 5.0 / CreoElements/Pro 5.0 are at least). I've been running it under 7 Pro 64-bit and have had less crashes than I get under Windows XP.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 02-01-2011, 19:03
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
I got the online installer to work on 1 of 3 windows 7 64 bit computers i have but it took 5-10 tries and you needed to do 3 installs with different options in a specific order which i cant remember to get it to work right. I literally got it to work once by blind luck. Now every time i try i get it through the installation but then it cant find Pro-E.exe
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 02-01-2011, 19:45
Roboticsrob
You really do need to download the full installer, it will fix all your issues.
Unread 02-01-2011, 19:50
klmx30302's Avatar
AKA: Kevin McCarthy
Can you get the full installer through windchill? I cant even remember where i got the installer i have now.
Our team motto...
Unread 03-01-2011, 08:28
skotmorris's Avatar
Any specific problems you are having with it? I have not had any issues running the Pro/ENGINEER Wildfire 5.0 (M040) Schools Edition on my Win7-64bit machines.
Unread 03-01-2011, 12:29
Roboticsrob
Yep, the full installer is right there on your Windchill project page. Go to Home --> Utilities --> Software Downloads --> and download the CreoElements/Pro 5.0 full DVD (rebranded Pro/E Wildfire 5.0)
Unread 03-01-2011, 14:47
klmx30302's Avatar
AKA: Kevin McCarthy
oh, i didn't know the name had been changed... i ran across this 3 or 4 times looking for a thing that said download pro-engineer 5.
Our team motto...
Using ProE Erik Pro ENGINEER / Creo 10 26-02-2009 14:06
pic: Orbitz ball modeled in ProE rachakate Extra Discussion 4 04-01-2009 15:47
ProE Assembly Editing daramana Inventor 5 31-01-2005 13:21
proE wildfire vs autodesk inventor ryan_f Inventor 6 18-12-2004 21:36
