Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 15-07-2010, 01:04
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Throttle Axis on Logitech Extreme 3D Pro
Greetings!
I'm trying to figure out the way to reference the throttle on the Logitech Extreme 3d Pro. We're using C++. I'm assuming that since this Joystick has 3 axis on the joystick (x, y, twist), the throttle (slider) and 12 buttons that the joystick initialization would be:
myJoystick = new Joystick(1, 4, 12);
Or, does the POV hat show up as a 5th axis?
Next, once I've got the Joystick instantiated, I should be able to read the axis as:
myJoystick->GetAxis(kThrottleAxis);
And it should return a value between 0 and 1 or -1 and 1?
If any of you have any sample code you'd care to part with, I'd sure appreciate it. Our main software developer is in a canoe up near Canada. So, I'm trying to figure out this stuff as quickly as I can.
Thanks,
Mike
Unread 15-07-2010, 01:10
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: Throttle Axis on Logitech Extreme 3D Pro
What we do is instead of creating a custom joystick object is to instead use the default joystick object. Using that, and the getRawAxis() function, with printf or cout, you can see which axis is being manipulated when you change the throttle.
Basically:
joystick *MyJoystick;
MyJoystick = new joystick();
printf("Axis 1: %f Axis 2: %f ....", MyJoystick->getRawAxis(1), MyJoystick->getRawAxis(2));
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 15-07-2010, 01:29
Software Mentor
AKA: Mike Anderson
Great! I'll give that a shot to see what the robot does!
Thanks,
Mike
Unread 01-02-2011, 16:17
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Originally Posted by taichichuan View Post
Greetings!
Thanks,
Mike
Do anyone know how to program the hat switch? is it a axis or is it a button?
im using java.
Unread 01-02-2011, 16:32
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
im using java.
It's axes. I think it's 5&6.
FRC Joystick throttle problems cvitullo C/C++ 6 14-04-2010 20:46
Logitech Dual Action (Axis Issue) j.cole NI LabVIEW 5 02-02-2010 21:16
Logitech Dual-Action Gamepad - Axis Problem Mr. Lim Programming 5 16-01-2010 19:28
logitech extreme 3d pro joystick mahmosh Control System 4 24-02-2009 08:36
Extreme 3D pro support? FreakyAntelope Control System 5 01-02-2007 12:30
