#16
Re: Teleop Issue - Motor Control Seems to Freeze
We have our kicker state machine running as a parallel task in the main.vi. That way it can run in both teleop and autonomous without delaying anything else. You can see this in this thread where this issue has been discussed already.
#17
Our kicker sequence is extremely dependent on the Watchdog Delay and Feed in that the solenoids need to be accuated in a certain sequence and needs the delays in as well. The kicker would not work without the solenoids accuating in order or the delays. The code itself probably explains it better than I can. The first image is the kicker sequence within Teleop only. When our driver presses Button One on Joystick 3, our robot kicks. The problem with this code is that it seems to freeze the Tank Drive Joysticks. The second image is the kicker sequence in Periodic Tasks. With this code, the driver can control the Tank Drive but the kicker sequence stops midway and does not complete itself. I have not yet tried using global variables to fix this problem. I'll post up an image of that code when I make it. |
#18
Hm, the codes I have posted above still seem to freeze up the joystick control when the kicker is activated.
Are there any other options or ideas that could fix this? |
#19
Yes, the code you posted for Teleop will freeze your driver controls for the duration of the kick sequence.
Concentrate on fixing your Periodic code. At what step does it stop working? P.S. The code left in Teleop on the outside of the Case statement (where you set the four solenoids) will override the Periodic code and mess up the kick sequence. Even without pulling the joystick trigger. In Periodic that code outside the While loop only happens once per robot boot, but the Teleop outside code happens 50 times per second. Last edited by Mark McLeod : 13-04-2010 at 19:24. |
#20
Once you have the kicker code all in Periodic Tasks, you can delete it from Teleop.
#21
I think your problem may be the Delay and Feeds in your Periodic Tasks case. Right now, when you press the joystick button, it picks the true case and executes all the solenoid and watchdog vis in the order defined by the error lines. Since the delays total to 3 seconds, I think it will take 3 seconds to run this while loop once when you start the kicker sequence. I'm not sure if this disallows Teleop from running (I kind of doubt it, this it is running parallel to and independent of Timed Tasks in Robot Main), but it may cause some undesirable overhead. At the very least it will keep everything else in that 100 ms loop from executing properly (whatever else that is).
A state machine is probably what you want here, as it will execute each of these steps in the kicker sequence at the appropriate times without interfering with the rest of your code. We have a state machine for our kicker that stores a variable (enums are usually appropriate) for the current state, such as loaded, fire, wait, reload, wait, etc. or however your kick sequence goes. In periodic tasks, a case structure reads this state and picks the appropriate case, and it is these cases which contain the solenoid set VIs. For the timing you could use a tick count block to store a time when you first enter a state, and then go to the next state (write the next state to the state variable) when the desired time has elapsed. Actually, our state variable is jsut initialized outside the while loop and then fed back with a shift register, so only the state machine can change its own state. Hopefully that made some sense... I've attached our Periodic Tasks.vi. Our state machine is in the 20ms loop, and reads the global variable Kick?, which is set to the joystick button in TeleOp. |
#22
A state machine is a viable alternate way to do this sort of thing, but many teams have successfully used a concurrent periodic task. We were successful using both approaches. We started out using state machines, then switched to using event-triggered periodic tasks. The periodic tasks approach is easier to look at and see the sequential flow. Makes it easier for peer review, particularly for inexperienced programmers. ~ |
#23
So is this concurrent periodic task the same kind of sequence structure or delay and feed structure that he used? Cuz I'm pretty sure both of those would still take the whole 3 seconds for one execution once its triggered, which may be fine if it's entirely independent of other tasks (like driving). And what do you mean by event driven? Our state machine could be classified as event driven in the sense that it waits for a button press to begin the state sequence.... Or did you set up some error handling in LabView? (something else I haven't really looked into at all) |
#24
event-triggered. an event (the press of a joystick button) triggers the periodic task to go do something. for example: you could set up your kicker as a separate 50ms periodic task that normally does nothing except check to see if the "kick" button is pressed. if the button is pressed, it goes through the kick cycle, taking as long as it needs. It can take as long as it needs because if it's in a separate periodic task, then it is run concurrently and doesn't prevent other robot tasks (like driving) from running. ~ |
#25
I compeletely removed anything related to the kicker sequence from Teleop and the code now works perfectly.
Thank you for all of the help, everybody! (: |
#26
You problem may be in the sequence. I was having a similar problem triggering solenoids within the teleop, and the sequence itself was delaying drive operations from runnning in real-time.
I fixed this by using a few case structures and feedback notes to keep the extending solenoid enabled and the retracting solenoid disabled while the trigger was held and the inverse when the trigger wasn't held. Timing operations can cause a delay. Another option would be to make an entirely new SubVI in Robot Main so kicking runs in parallel with drive. |
| Labview Servo Control Issue | EricWilliams | Programming | 5 | 22-01-2010 14:24 |
| Jaguars Slow Yellow Blink - Possible Control System Issue | MikeDubreuil | FRC Control System | 3 | 26-01-2009 23:04 |
| Driver Station Watch Dog / Motor Won't Spin Issue | RMiller | FRC Control System | 5 | 20-01-2009 09:58 |
| Small Banebots Motor Issue - Lessened torque and smoke | sanddrag | Motors | 10 | 12-02-2007 21:41 |
| CIM motor issue | dmellich | Motors | 4 | 11-02-2005 11:10 |
