Go to Post Life is so much better when you do what you love rather than what others want you to do. - KelliV [more]
Unread 17-07-2010, 23:13
Re: [need help] push button cylinder/game pad controller
That's the one called a Feedback Node.
You'll see it in the palette as just an arrow, but when you paste it into a block diagram it'll have the diamond underneath it. The diamond is a way to set the initial value you want it to start with.
After you place a feedback node it will be black and you won't be able to do much with it until you tell it what data type it will be saving for you.
Follow up by adding a Boolean True or False from the Programming palette and wire it to the diamond. Then the Feedback Node will turn green, the color of boolean data types. That is what the Solenoids are expecting as inputs to the Set vi.
Unread 17-07-2010, 23:22
If you use a double solenoid, it does it automatically.
Unread 17-07-2010, 23:24
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
it is a little messy, but should this work?
http://img685.imageshack.us/f/togglepiston.png/
Cory S.
~Team 1529 Cybercards~
Unread 17-07-2010, 23:28
You just need to add the False CASE.
That's a wire straight through from the tunnel on the left to the tunnel on the right.
Seems fine otherwise.
Unread 17-07-2010, 23:33
FRC #1529
I don't follow. i just added a wire from the diamond pointing left to the true/false (currently false) toggle switch thing.
Unread 17-07-2010, 23:46
In the picture you posted there is a hollow green box (called a tunnel) on the right side of the CASE structure. I circled it in a copy of your photo below.
When it's hollow like that it means you haven't attached it in all the CASES, so it's incomplete. You'll also see there's a broken arrow for the vi in the upper left menu bar.
You've done the TRUE case, but you need to switch it to the FALSE case and just connect a wire across from the left green box to the right green box.
Unread 18-07-2010, 00:01
FRC #1529
ohh, thanks. i just added that and i have no errors now. thanks for the help! There is one more thing i'm trying to figure out. I don't know how to run the compressor in autonomous mode. Is that a complicated process or is it simple? i can't find any threads about that. I tried to do the same thing i did in teleop but it didn't work. you can see the teleop compressor code labeled GAS in the picture I posted.
Thanks again for all your help. I hope to learn as much as i can about labVIEW and programming before the next build season so the programming skill is not restricting to the robot's capabilities. You have helpedme alot!
Cory S.
Unread 18-07-2010, 00:09
The compressor code belongs in Begin.vi, so that it's active all the time to support both Auto and Teleop.
Here's a link to an example of how you start it in Begin.vi: http://team358.org/files/programming...orExample2.jpg
There are some other examples on that page you might find useful: http://team358.org/files/programming...2009-/LabVIEW/
Unread 18-07-2010, 00:13
FRC #1529
oh, wow. I never knew you could do that! Thank you very much!
Cory S.
Unread 18-07-2010, 00:22
FRC #1529
i just looked at my code. it is the same except i had compressor code in teleop.vi and i did not have anything in finish.vi. if i delete the code in teleop and add the finish code it will then run all the time? Why wouldn't it run in autonomous as-is though?
Unread 18-07-2010, 10:08
I can't see how the compressor is used in the Teleop photo you posted.
What's shown is nothing at all, but I can't see what's in the other Teleop cases.
It's probably something you don't realize is even happening.
The Finish.vi part won't affect compressor operation. That's only when the program shuts down.
Normal IO Push Button on the Digital Sidecar DaSavageJ Electrical 4 07-02-2010 17:43
Driver Station Push Button coolperson987 General Forum 6 12-03-2009 22:17
Automation Direct Push Button MPG Electrical 2 19-02-2009 22:56
Push Button System Rob2713g Programming 5 08-08-2006 21:20
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
