Go to Post Spread inspiration; Don't destroy it. - IntensifiedAmp [more]
  #31   Spotlight this post!
Unread 16-07-2010, 15:33
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Any good summer electrical projects?
Ah, yeah, the Jags are pretty awesome because of that. You can get the Victors here:
http://www.robotcombat.com/products/IFI-HV48.html
And the datasheet is here:
http://www.ifirobotics.com/docs/48v-...heet.pdf?q=48v
They are fairly pricey, but good DC motor controllers in that power range are. If you don't need 90A continuous power I would scour eBay or google products search for 48V motor controller. Good luck in your project.
  #32   Spotlight this post!
Unread 17-07-2010, 13:59
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Originally Posted by Alchemy99 View Post
all thoes are fun projects, but i dont know how far you are in your electronics expertice, but this is my project and i need help (see 3d printer help) but in gereral i am makeing a 3d printer based off the RepRap project (reprap.org) so if you are looking for something kit and direction based it will run you about $500 to get a desktop 3d printer. or you can do it the more complicated way and change everything untill you are a chicken with your head cut off trying to figure it out.
As awesome as that would be, I just don't have that much money to drop on a project at the moment.
Also, here's a quick question: I'm trying to build an intervalometer (timed trigger for time lapse photography) using a 555 timer. the schematic I'm going off of calls for an NE555 timer. What I can pick up in town are the TLC555 and LM555 chips. Looking at the spec sheets I can't tell a significant difference between them, but I'm not sure. Are there any significant differences between chip numbers I should be aware of? or are they just different numbers between manufacturers?
  #33   Spotlight this post!
Unread 17-07-2010, 21:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I think the 555 timer is pretty well uniform between manufacturers, but the pin-out might vary. As long as the data sheets are the same you should be fine.
  #34   Spotlight this post!
Unread 18-07-2010, 01:01
AKA: Chris Sherwood
alright. that's the impression I was getting, but I just thought I'd make sure
  #35   Spotlight this post!
Unread 19-07-2010, 07:40
Chris,
555 timers are for the most part interchangeable. Some manufacturers have added something to make it better but still equivalent. There are CMOS variations as well. The CMOS requires less power supply current but can't handle higher output currents like the standard version. You might try getting several and fooling around with some to make wild noises as an audible alarm when the time out is reached.
  #36   Spotlight this post!
Unread 19-07-2010, 16:06
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
Originally Posted by Zholl View Post
So to all you more experienced electrical types, what kind of electrical projects or learning resources can you recommend to a high school student like myself?
I would welcome you to come out to Monroe, and help me wire in the power windows that I'm trying to transplant into my car. I need help!
Madness?
THIS IS F.I.R.S.T!
2009 Summer Projects boehmz 3D Animation and Competition 12 10-07-2009 02:04
Summer VEX Projects? Donut VEX 17 30-06-2007 01:53
Any students good with flash willing to undertake few simple projects for offseason? Ken Leung General Forum 1 16-10-2006 11:34
CMUcam summer projects Andrew Schuetze Control System 5 01-06-2005 09:29
summer projects oreocookeee Chit-Chat 1 05-07-2002 23:17
