Go to Post ...isn't that part of the point? For high schoolers to do things they "could not have" by themselves? - AdamHeard [more]
Unread 19-07-2010, 16:14
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: pic: 1625's 2010 Robot
Originally Posted by Zach O View Post
Awesome robot! I have a question. What did you use to continue lifting after time went off? Did you use the same thing as 67 did, or did you have another way to go about doing it?
Edit: Got the answer. A limit switch and gas shocks?
They used a set up very similar to HoT's. HoT used 4 200 lb gas shocks, Winnovation used 3 250 lb shocks. The most notable difference in the two systems is in the release. Hot had a mechanical release on a truck latch (I believe off an Impala, but don't hold me to that) so when they released their hanger if it didn't hit the bar before the buzzer the gas shocks would still release.
1625 had a limit switch on their new latch (now similar to RUSH's latch) that said when this limit switch is tripped use servo to release gas shocks. HoT therefore has a slight time advantage because they don't need power to release, but on the other hand they also need the bump.
There was also a difference in the method the teams compressed the shocks. Winnovation used a heavily modified cable winch and HoT built their own hand crank. Both systems are remarkably impressive and effective.
Zach if you have any other questions I have detailed pictures of both.
Kudos on a great bot 1625.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
pic: 548's 2010 robot Bjenks548 Extra Discussion 10 19-05-2010 21:40
pic: 1557's 2010 Robot gorrilla Extra Discussion 15 24-02-2010 02:06
pic: 1625's swerve module (better pic) Aren_Hill Extra Discussion 25 22-07-2008 19:14
pic: 1625's shooter ready to fire Aren_Hill Extra Discussion 24 19-06-2008 01:44
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
