Go to Post My students like to win, so I'll stick to enabling that. - sdcantrell56 [more]
Unread 19-07-2010, 18:40
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Wireless problem
hello i have been trying to get the classmate through the router to communicate with the robot. so basically,
computer communicating with the router that is on the robot with the bridge.
I have modified the router settings so that the computer links with the router wirelessly and it works and have video feedback but the DS says no enet link which i would expect, but how do i get the DS to let me enable the robot?
Unread 19-07-2010, 20:02
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: Wireless problem
You could try disabling the ethernet port on the DS. Not sure if that would fix it, but the DS software might look for it on the wireless then.
Unread 19-07-2010, 21:42
AKA: Jon
Would that be disabling the local area connection or is there another way?
Unread 19-07-2010, 22:59
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Yes, that's disabling the local connection.
-- Marshal Horn
Unread 19-07-2010, 23:16
AKA: Jon
Thats what i thought and no it was still looking for an enet link.
has anyone gotten the wireless operation to work?
p.s. even plugged in it would not give comms till the wireless was disabled
Unread 20-07-2010, 00:02
The Driver Station needs the appropriate IP address in order to communicate with the robot. To run wirelessly, try setting the wired LAN connection to use DHCP ("obtain address automatically" or something like that) and set the wireless LAN connection to use the 10.X.Y.5 address. You might also have to disable the wired connection completely to keep the DS application from trying to reconfigure it.
Unread 20-07-2010, 14:59
AKA: Jon
I got it to work by switching the local to dhcp thanks Alan.
Now is there anyway to eliminate the bridge from the equation?
Unread 20-07-2010, 15:08
Put the wireless router on the robot.
Unread 20-07-2010, 15:10
AKA: Jon
I already did that but Can I plug the crio into the wireless router?
Unread 20-07-2010, 15:19
Yes, plug the cRIO directly into the router. The DS will complain that it can't ping the bridge on the diagnostics tab, but that's just diagnostics, it doesn't affect the operation.
Unread 20-07-2010, 16:44
AKA: Jon
Great thanks all
problem getting wireless router/bridge talking sam3062 Programming 8 23-02-2010 16:36
Wireless Connection Problem Matt2081 Control System 16 21-02-2010 13:59
Wireless Connection Problem!!! EagleS!! General Forum 5 28-01-2010 07:56
Wireless Connection Problem jaustin FRC Control System 18 18-01-2009 13:41
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
