Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 21-07-2010, 08:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Gearbox issues
Originally Posted by Chris is me View Post
I would say 20mph is much higher than an "average" roller blade rider. 15 mph is a lot more accurate.
I based that number off of 3 years of experience riding on roller blades in NYC. I would routinely go 1 mile in 4-6 minutes (my commute to college) averaged between going as fast as I could, going slowly to navigate around pedestrians, and waiting at crosswalks.
Originally Posted by PortugazD.Ace View Post
The assist motors are meant to take your kick, multiply the would-be resulting speed by 1.5-2, then use that result as the output speed of the wheel. So, in short, your speed gets increased by 50%-100%. Get where I am going so far?
I think we do.
I have discovered a motor that could lift an average 7-year-old off of the ground. It has been proven that a window motor can move at least 60lbs. use four of them, and you get up to 240lbs that are able to be moved. and they are quite small two. They will even fit inside my space requirements.
Force or torque should not be confused with power. Sure the window motor can move that much mass, but very VERY slowly. Being powerful means that the motor can move the weight QUICKLY, not just simply move it. I also don't think that they are designed for continuous duty, I wouldn't choose to use them.
15-20mph is about 22ft/s-29ft/s, or roughly 2-3 times as fast as the fastest FIRST robots, and they are typically using 2-4 CIM motors which are good for ~340watts of power (as mentioned before). Two CIM motors, gear properly, would probably get the job done for what you want to do, so I would aim for 600-700watts of motor power. Combined with the power a person can output, you'll be at about 1000watts total.
I will point out that having 1lb on your feet is worth carrying 6-7lbs on your back (a rule of thumb for hikers and runners) so if you have 8lbs of motor and gears on your feet it'll feel like carrying about 50lbs on your back. Maybe the flexi-shaft drive isn't such a bad idea...
Unread 21-07-2010, 09:12
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Re: Gearbox issues
A little reply to that last pargraph, I walk around with two 2.5lb ankle weights straped to my legs. but I get where you are going with the power needed to do what I want it to do.
Latin:
"Murmure ventus erit parere Tempestatem"
"Noctu teneris vinculis
Nocte illa vincula adimuntur"
Holonomic issues dwodrich NI LabVIEW 11 02-02-2010 21:19
Pneumatics Issues pyr0b0y Pneumatics 4 13-02-2009 20:24
IP issues brainsdmaner FRC Control System 1 07-02-2009 22:35
TTL Issues Bomberofdoom Programming 4 31-01-2007 09:23
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
