Go to Post To the best engineers, scientists, and thinkers, something that is "hard" isn't something to avoid; it is something that begs for us to prove that we can do it. STEM is built on the very idea of trying something, failing, and trying something different. - Bryan Herbst [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-07-2010, 15:53
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Chassis Connections
We have welded our chassis all of our years as a team. For a while our rookie year we were going to use the kit chassis, so we bolted it together, welded, then removed all the bolts. I don't remember the specific weight of the bolts and supports, but it was well over 5 lbs. We ran into trouble with the kit frame warping during the welding, so we made our own, and have done so every year so far.
If you are trying to decide what to do, I would definitely weld to save some weight. The next best option (imho) are aluminum rivets. I don't know enough about them or have enough experience to give a big recomendation, but I have seen them work very well.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Encoder Connections TonyP CAN 1 08-02-2010 22:26
Jumper Connections Lord Byron Electrical 4 26-01-2009 20:43
Field Connections? xxMORT11xx FRC Control System 4 24-01-2009 21:51
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
