Go to Post The bleachers at a FIRST competition should be full of people blasting energy out of every pore of their bodies. - dlavery [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-07-2010, 16:03
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Chassis Connections
Originally Posted by Hawiian Cadder View Post
we have always used the pancake design with aluminum plate. typically this takes around 150 metal screws. however when designing the robot this year we didn't really do the math and ended up with around 1400 holes. the box of screws, (2000 8-32 5/8 long button head) weighed almost 10 LBS. lock tight application for the whole robot took 5 people around 10 hours.
due to this, we are going for angle gussets with 1 inch box tube this year, hopefully it will be easier.
I'd love to see a picture of this "pancake design" that used 10lbs of fasteners...
Unread 22-07-2010, 16:58
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
This year, we used lots and lots of bolts. Our whole robot was basically various sizes of aluminum angle, so we just had angle inside angle bolted together with at least 2 bolts.
In the past, we have welded (only drivetrains), used gussets and rivets, and used 80/20 extrusion.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 22-07-2010, 17:13
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
1350 uses bolts and nyloc nuts everywhere. It makes prototyping easy since we can easily build, test, and rebuild any part (easy until you find you built an integral structural or functional component directly over the bolt head you need to get to which can't be moved since EVERYTHING is bolted onto it, but thats OK, it builds dexterity). The real issue comes when everyone is fighting to use one drill bit or wrench that is the only one of its size and happens to be the correct one for EVERY bolt on the robot.
We also like zip-ties, but not so much for the chassis.
Unread 22-07-2010, 17:12
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Through the years, we have built a bolted chassis, a riveted chassis, a glued and nailed chassis, and a welded chassis. All have held up to the stress of 2+ regionals without issues.
You can build a chassis that is strong and light in countless ways if you put enough design work into it. The thing you need to ask yourself is how you can best utilize your resources to build a strong/light chassis as quickly as possible. The faster you can finish fabricating it during the build season, the better.
I would also encourage you to take a look at the big picture when you are designing your chassis. Robot functions change drastically from year to year and greatly influence the design of the drivetrain (hence why we have gone through so many different forms). Remember that you are designing and building a complete robot; the chassis and manipulators are not always independent systems.
Encoder Connections TonyP CAN 1 08-02-2010 22:26
Jumper Connections Lord Byron Electrical 4 26-01-2009 20:43
Field Connections? xxMORT11xx FRC Control System 4 24-01-2009 21:51
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
